12-29-2021, 08:11 PM | #1 |
Rear window removal and bolt sizes, emblem
I recently found on small window cab in a junkyard with a good back window and was wondering how to get it out without breaking/messing it up? I was also wondering what size the nuts and bolts are for the tow hooks? My last question is that there is a small badge/emblem on the dash by the ignition switch and I think it says air conditioning, and I was wondering if it's a onetime use part and if not, how do I remove it without breaking it as well?
Thanks to those who reply Jack |
12-29-2021, 09:12 PM | #2 |
Re: Rear window removal and bolt sizes, emblem
a box cutter will take the window out just cut the rubber its usually easier to cut from inside while someone holds it from outside but you can tape it up real well . im usure about the rest
12-30-2021, 02:57 PM | #3 |
I believe it says Acc Off ON Start. This wasn't used on a 67 as they didn't incorporate the accessory setting till later years. Highly likely it will b upon removal. If you pain the dash be sure to remove any pant from the holes. It's a tight fit. Don't attempt to save the rubber for the back window. Just cut it out and purchase new. Last edited by Accelo; 12-30-2021 at 03:04 PM. |
