Old 12-30-2021, 01:54 PM   #1
kljfamily
exhaust manifold interchange
Hello group!
65 c10 stepside
installed a motor I found off of craigslist from a 1978 c10. Its a 250.
The exhaust manifold is an odd size. I keep ordering the exhaust flange to hook up the exhaust(walker 31883) but it comes in with holes spaced 3" apart and this particular manifold has the bolt spacing at 2-3/4. I've tried ordering the flange from a variety of sources but it comes back wrong each time. I think this may have to do with the 78 having the integrated or non integrated head. this particular one is non-integrated.
Here is the motor info:
The intake is a gm 343303 43 and exhaust is a gm504
motor: con2 f168 377127 gm 86 then behind distributor f0622tar
I took a look at the walker exhaust system website for the 78 and it shows two options for the 250 in that year. The first has the collar 31183 and then the second doesn't show a collar. I'm assuming possibly the collar was built into the exhaust pipe.
My question is this:
Can I use the exhaust manifold from the 65 230 engine I have (Blown engine) and then just hook up the stock exhaust easy.....or is there something Im missing on this 78 engine?
I just finished up the body work and bed so I'm broke and I know I should probably just take to midas and have them custom fit it but I'd like the finish up this ground up restoration myself and I have done every part of it so far.
kljfamily is offline   Reply With Quote
Old 12-30-2021, 03:48 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: exhaust manifold interchange
Without looking at the manifold in question it would be difficult to answer.
Old 12-30-2021, 05:36 PM   #3
cwcarpenter98
cwcarpenter98's Avatar
Got some pictures of the engine you put in?
If it's a non-integrated head, and the intake and exhaust ports line up with the old manifold you pulled off, you should be able to use the old manifold on the newer head
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 12-30-2021, 09:30 PM   #4
geezer#99
geezer#99's Avatar
Is it possible you have a 292 manifold.
I think the newer 292’s had the 3 inch flange.
Of course pics help.
Old 12-31-2021, 01:10 AM   #5
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Don't know.
Nice red though.
66 C20 Service Truck:
Old 12-31-2021, 06:19 PM   #6
kljfamily
ok thanks,
I know its a 250 from the engine # and the # behind the
distributor. I ran it on the novak site and it comes up as a 1978 250 out of flint for a c10.
also know its non integrated after looking at this post:
http://67-72chevytrucks.com/vboard/s...d.php?t=282381
I think I will just take your advise and swap out the stock exhuast manifold from the 78 with the original 65 I have and the problem should be solved thanks
Old 12-31-2021, 06:28 PM   #7
kljfamily
ok thanks,
I think I will just take your advise and swap out the stock exhuast manifold from the 78 with the original 65 I have and the problem should be solved thanks.
I also added phots of the engine if that helps
Old 12-31-2021, 09:04 PM   #8
Warrens69GMC
Warrens69GMC's Avatar
flipped
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 12-31-2021, 09:18 PM   #9
Warrens69GMC
I'm not certain, but you may be missing the heat riser valve.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 01-01-2022, 03:16 PM   #10
kljfamily
heat riser? thanks. I look that up and yes I do not have that piece on there.
2 questions.
1. is it necessary
2. would that possible change the bolt spacing?
Old 01-01-2022, 06:18 PM   #11
kljfamily
OK, I did the research on the heat riser and answered my own question.
Thanks everyone
