Olds/Caddy air filter
I was lookong at these online and wondering if they clear our firewalls. Speedway Motors has a full size and a 7/8 size version. Anyone running one of these?
Moderator
![]() ![]() Join Date: Aug 2011
Re: Olds/Caddy air filter
In theory - http://67-72chevytrucks.com/vboard/s...&postcount=219
And then he did it - http://67-72chevytrucks.com/vboard/s...&postcount=249
It's Better With Nitro
As long as your engine placement is in the stock location, you should be fine.
![]() Join Date: Dec 2009
I see these at Swap Meets from time to time.
I think they look cool.
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
Thanks guys, yes my engine is in the stock location, but I do have a 1" carb spacer. They have a spec sheet at the Speedway site and I will check it thoroughly but first hand info is always the best. Presently, I use a modified squarebody housing and it's getting harder to find replacement filters (don't want a K&N). Also, I'm kind of tired of hearing my carb sucking air. Hopefully someone who is currently using one of these Caddy jobs will check in and tell me how they like it
![]() Join Date: Nov 2015
I have one in my '64, but I'm running an Oldsmobile 455. It is super close to my heater core box but fits. I believe mine came with a drop air filter base but had to use an air filter base that kept the bottom of the air filter even with the top of my carb. It clears the hood, too.
#7 | |
AcampoDave what's the cost on it? I was debating on this idea for a while. I have a 283, edelbrock carb and intake set up on mine. I wonder if it will clear a HEI dist cap? Maybe depending on the spacer?
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
![]() Join Date: Feb 2016
i like this one.
i have a 396BBC and was trying to find something aggressive and for the time period. |
#10 | |
https://www.speedwaymotors.com/Retro...bile,1052.html 7/8 and full size links |
Revitalizing a 6T C10
![]() Join Date: Aug 2017
I believe roll_the_dice did as well :
http://67-72chevytrucks.com/vboard/member.php?u=164669 http://67-72chevytrucks.com/vboard/s...&postcount=713
1960 C-10 Apache- "Rusty the Redneck Reject"
1/2 Ton short bed step side. 350 crate motor, 3 speed manual (floor shifted) MKII - Buddy Buckets and Glass Packs 20+ year long term project in process Lots of Rust, more memories... |
That's right, It was Dice Roller who had that. I knew someone had one painted to match and couldn't remeber who. I PM'd him. I haven't seen him around here much anymore. Maybe my query will inspire him to drop in again. Thanks
#13 |
Moderator
Pretty good dimension here - https://www.mooneyesusa.com/product-p/aa520.htm
O'Brians usually has some interesting stuff - https://www.obrientruckers.com/air-c...s-batwing.html
#14 |
![]() Join Date: Jan 2011
I have one and with the engine in the stock rear mount location the filter hit the firewall. I do have a super victor intake and a 1/2" spacer.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#15 |
Sorry for taking so long to reply. Mine is about 18" wide. Here's a picture of it in my '64. Still need to paint it, though.
