Old 12-28-2003, 09:18 PM   #1
Injected68LS1
Injected68LS1's Avatar
Anyone sell a non-solid, lower-a-arm shaft??
So I have these MOOG lower control arm shafts. I know they are of good quality BUT they weigh a ton. They are a sold 1-1/8 inch shaft. that's bigger than my front sway bar.
Anyways.....Does another company sell one that is drilled though the center? I know these don't need to weigh 20 lbs. each.
Thanx
1968 Chev SWB with 1998 Corvette LS1
305hp and 320 ftlb to the wheels (stock engine!)
AEM EMS and wideband O2 sensors
Bowtie Overdrive's 700R4, stage 3
Baer 4 wheel discs and 20s
http://iciclelanding.com/aperture?album=2049&view=album
Injected68LS1 is offline   Reply With Quote
Old 12-28-2003, 09:41 PM   #2
dinnut
dinnut's Avatar
i would think they have to be strong and have to be solid... just a guess
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 12-28-2003, 10:14 PM   #3
Injected68LS1
Your right about them having to be strong. But those shafts could support a 1-ton wrecker or a tank. Do you have any idea the strength of a 1-1/8" bar of steel?
I would also buy aluminum spindles if somebody made them. There is no need for a half-ton truck to have stuff this heavy duty. All they are is heavy.
Old 12-29-2003, 12:28 AM   #4
Stroker
Ye it would be nice if there was an easy way to shave some weight from the front suspension besides doing the mustang conversions. I've never seen any aftermarket or modified shafts for these trucks, some forged spindles would also be nice and save a little weight. Sorry I'm not any help but this will get you back ttt. Good luck........Stroker
72 SWB parts and pieces
Oklahoma
Stroker is offline   Reply With Quote
Old 12-29-2003, 12:46 AM   #5
Injected68LS1
I should do some stress calculations on the spindles and the shafts. I bet you could do over 6g on the skid pad. I bet you could also apply 10 tons to the lower control arm(pulling outward toward the side of the truck).
Old 12-29-2003, 02:49 AM   #6
Rooster's 67
Rooster's 67's Avatar
how about using the 73-87 uppers, with the rubber bushings? little softer ride or put in poly.....stiffens it up but lighter than the metal bushing set up.
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
