![]() Join Date: Nov 2012
Paint job cost
I have a blazer being done and its been a long time since I paid for body and paint work and things are starting to add up to a little more than I was thinking. I'm in 10 grand with a charge for 180 ish hours,or roughly 4 and a 1/2 40 hour weeks. The usual inner and outer rockers,weld in donor taillight sections due to serious dents,some outer wheel well work where someone squeezed thru something they shouldn't have,a little lower a pillar on one side and some lower b pillar on the other side,reskin a door and replace the lower inner bottom on the other,a few parking lot dings and a handful of screw holes. The work is good and is being done in a fashion for lasting a long time,not a retail body shop but a guy renting a shop at the wrecking yard I stomp thru,he has been there for a few years and I've seen some nice stuff come out and one day when scrounging I hit him up. At this rate I think its gonna go 15 k for the full meal deal.I am expecting to be the one to assemble it other wise I think it would run me about 5 grand more for the Super size full meal deal.
What do ya think? |
![]() Join Date: Apr 2021
Re: Paint job cost
I have been hearing the average for start to finish with paint 8-14k depending on rust work/replacement.
I would like to hear other opinion. I know paint, reducer and Clear will run $800-$1200 depending on paint manufacturers. |
![]() Join Date: Jan 2021
Re: Paint job cost
Wait till you start paying for paint and clear coat, I am doing all the body work myself. My cost on paint is $800 a gallon, clear is $300 a quart, full price is almost triple that. Paint is the new corvette paint which has some pearls in it so that drives up cost. Clear is not the most expensive one but you can’t skimp on that. Good luck on your project. Chuck
Posted via Mobile Device |
![]() ![]() Join Date: Sep 2008
Re: Paint job cost
I do all the disassembly and body work. When the parts go to the body shop they are ready for final block and primer and paint. When I get them back, I assemble everything. I usually get out for under $10,000 including materials.
I can see where a full on job with panel replacement and body work could cost upwards of $20,000 with materials. If somebody is actually working on your rig, count yourself lucky.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
Re: Paint job cost
My primer, paint and clears ran me ~$3500 just for material. A lot depends on what line you're using.
1972 C20 |
Re: Paint job cost
I'm probably 2 grand in paint and primer alone. I get a pretty good discount on supplies, too. Some of the base coat paints are $1000.00 a gallon. Then you've got to buy clear. I'd hate to think how many hours I have in body work. $15,000 probably isn't out of line. I had a guy quote me $8000 just to shoot paint on my already prepped body. That's me buying the paint. I just ended up doing it myself. Most places around here are booked up for 2-3 years out. Plenty of money to be made in the paint and body business, if you don't mind hard work.
![]() Join Date: Feb 2004
Re: Paint job cost
I really like the gloss black, single stage polyurethane paint my friend is using on the 87 K10 stepside.
![]() Join Date: Nov 2018
Re: Paint job cost
This one was completely disassembled soda blasted, body worked, primed and painted. Paint materials alone were $2500 total bill was $13,500 my quote from the painter was $12k-$15k and that was in 2005. The first guy I had look at painting it told me, and I quote, "It is what it is, when I get done with it" Needless to say he did not paint it.
I don't personally think $15k is out of line. I can tell you a couple of horror stories of guys who have been screwed/raped by so called car painters. |
Re: Paint job cost
And I wonder why you can get BASF/ PPG/ Sherwin Williams at 25% of the cost in Mexico that you do in the US.
![]() Join Date: Dec 1999
Re: Paint job cost
No doubt that the paint itself is overinflated in the US. The two tone job on my truck with paint cost was almost 18K. I knew the painter and was able to do some work myself. Glad I knew the guy, to many horror stories of projects never finished. Probably almost 200 hours myself and would guess painter has over 400 hours in as well. For the time he had in it he gave me a good deal IMO. Really thought my truck was not to bad, something to think about. Decided to import a premium single stage for the 72 since the clear on my $7,500 two stage put on my 94 3 years ago is already failing. It was basically a feather, scuff and shoot. Paint by itself was over $800 a gallon on the 72. I am in the republic of Ca, YMMV on costs and paint quality due to your location. I did viisit 5+ shops on the 94 with the accident. Once I mentioned a repaint I never heard back from any of the paint shops here due to me wanting complete reshoot.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 01-08-2022 at 03:28 AM. |
Re: Paint job cost
A paint job around here would be $10,000-$15,000 with no bodywork. Any less than that and I wouldn’t have faith in the quality of the work. Around my part of the country the average is $100 an hour.
My 1972 two Wheel Dr. Blazer is at a well respected body shop north of Boston in Massachusetts. The previous owner swore my blazer was rust free. He even challenged sending anyone to look at it with a fine tooth comb. I take care of an elderly father and was unable to go look at it in person. It ended up needing both bedsides, both doors, I am switching to a 1968 front clip and was unable to find rust free fenders so he had to spend some time repairing the rust and damage around the headlight holes on both OEM fenders. The hood has so much oil canning he is 10 hours into it and probably needs another 10 hours to finish. He suggested possibly an aftermarket hood but after reading all of the work needed to make them fit I would rather have him work on an OEM hood. My tailgate just needed a few holes filled. I found an NOS bedsides, One NOS door, An NOS 1968 grill and hoops. There is also repair needed for the windshield frame and a little bit of the Cowl. Even with all the NOS parts I will be at about $30,000 when finished. I am too far into it to quit now.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
Re: Paint job cost
Some depends on what your'e going to paint, for instance inside the bed, under bed & cab, full inside cab, fire wall. There can be a lot surface area. Paint quality is also a factor as is the quality of the final job. 10 years ago I had all this done, two tone, one nickel size rust hole in the door, saddle tank doors removed and patched, a two or three very small dents, soda blasting inside and out, base/clear, bottom of bed and cab in single stage, few extra coats of clear to allow for color sanding later in life... $12K including little over $3k for materials.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#13 |
Mr. Cheyenne
![]() ![]() Join Date: Jun 2020
Re: Paint job cost
Gee, after getting my C10 White/Bronze/White, which was frame off restored ~12 years ago I guess I got a good deal on it for 15k. Granted I have put that (if not more) into everything else other than body work. Laymen ask me all the time did I just get it painted (she is a garage queen since that frame off restoration)! Granted, I know the places that aren't exactly correct or starting to come undone (like the drip rail area) - so she is far from perfect.
I had no idea on the cost of paint/body work, freaking scary. I want to go with a wood bed upgrade but that means some paint on the bed and I have thought, well perhaps get her repainted completely. Well, this tread has more or less killed that idea! Ouch!
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
#14 | |
![]() Join Date: Dec 2013
Re: Paint job cost
![]() PPG single stage is $300.00 a gallon in Knoxville .
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
#15 | |
Re: Paint job cost
Depending on color my price for single stage is a little more than Grumpy's. My 68 so far according to my spreadsheet paint and materials is $ 3900. Epoxy high build and 2 gallons of Nason single stage .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 01-08-2022 at 12:35 PM. |
#16 |
Re: Paint job cost
Thanks guys,feeling better about the paint job.
#17 |
Re: Paint job cost
Glad your feeling better, it sounds like you are getting a fair price.
I calculated I spent about $5k on paint material, filler, primer, base, clear, cleaners, tape, masking, sandpaper, etc. I did all the metal work and I can't even imaging how much it would have cost for the amount of work and detail I went to. Had a guy helping me when doing body and paint and spent another 3-4k on him doing most of the grunt work, sanding, cleaning and masking. I did plenty of shaping filler, block sanding and detail sanding and I was on the trigger but his assistance was invaluable. It allowed me to focus on mixing, spraying and QC. This was an all over paint and body, inside and out. |
#18 | |
Re: Paint job cost
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 01-11-2022 at 03:20 AM. |
#19 |
Almost Satisfied
![]() Join Date: Mar 2002
Re: Paint job cost
I think you are getting a good deal based on what mine ran. I would recommend going over the truck very closely before they blow it back apart to paint it. If you are doing the final assembly you want to make sure they have the gaps etc. where you are happy with them prior to handing you back a stack of parts and hoping you get them adjusted correctly. Tougher to make changes after paint.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
#20 | |
![]() Join Date: May 2011
Re: Paint job cost
This is the same situation that I'm in with my '71 K20. Purchased out of Washington State as a "rust free" original-paint truck. I know that "rust free" has different meanings to different people, and expected some rust. I was really hoping to keep the truck original-paint, but the paint on the hood and top of fenders was so burned off, I decided to have it painted. Upon initial inspection, it really did look like a super solid truck, but once a guy starts poking around and taking stuff apart, you see how "solid" something really is.. This is too cool of a truck not to give it some love, so down the rabbit hole I go!!! Truck now has new door skins, rockers, cab corners, a couple of cab supports, bed braces, inner fenders, outer floors, rad support, all the trim is new, glass, rubber, etc...and on and on and on.... I even bought another complete '71 just for parts. If I get out of this under $15k (body/paint), I'll be thrilled! (not holding my breath) Thankfully, a friend of mine is doing the work, so I'm probably getting more "value" for my dollar then is typical as I told him "no hurry"... Here's what she looked like when I bought it... Maybe should have left it alone? lol And what it looks like as of a couple of weeks ago. Moral to this story is BODYWORK AIN'T CHEAP!!!!!!!!!!!!! |
#21 | |
Mr. Cheyenne
Re: Paint job cost
I have recently discovered here in Kyle "Crossroads Restorations" - from their web page they appear to be a A+ operation.
I might just visit them, just to chat and look around. A snip from their Faqs Quote:
#22 |
Re: Paint job cost
There's a reason guys like me buy a gallon of Tremclad and a 1/2 decent gun and call it good enough.
My last paint job lasted about 10 yrs and at 61 I'll be doing another one in the spring. From across the street it will look good enough and if I get a scratch or two won't be a tragedy.
I got a bench seat baby, you don't have to sit over there. |
#23 | |
Re: Paint job cost
No my paint doesn't look like a $17,000 - $45,000 pro shop paint job but I can say I did it myself and every vehicle of mine I paint I get better at it. It really isn't hard guys. I replace what I can. On my truck it was new rockers. Patches in the cab floor. A couple of cab supports. I filleted one bedside, removed rust with a chin poker, acid etch, epoxy inside. Re-assemble, remove outer paint with chin poker, acid, epoxy, color. That sucked so I paid $450 for a re-pop boxside on the other side. Tailgate took two swings to get the painted letters right. I would never be able to pay $45,000 for paint on a 50 year old truck. I could probably pay the money but I wouldn't be married any more.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
#24 |
Re: Paint job cost
My recent experience (Finished 10/21) after disassembling my 72 K20 and doing all of the rust repair, welding, panel replacement as well as old paint removal down to bare metal before taking the whole she-bang to the body shop for complete repaint inside and out (different color). Total cost after nearly an entire year in the shop - $26K+
I shudder to think what it would have cost if I hadn't done all of the preliminary work (and reassembly) myself.... |
#25 |
Re: Paint job cost
My actual cost for materials were and I get a pretty good discount.
PPG Epoxy primer with catalyst: 1 gallon of primer $222.00, Catalyst $195.00.. 1-quart of urethane primer:$59.00, 1-quart of urethane catalyst:$28.00. 1-quart of 2 stage paint:$239.00 (list price is $486.00) 1-quart of activator is:$73.00. The clear with activator one gallon of product.$679.00 my cost. My body supply guy said that materials have gone up in price 30-50% since last summer and by next summer probably another 25-35%. So if you have a project that you want to do, better now than later. Thanks Chuck Posted via Mobile Device |
