Old 01-09-2022, 01:09 PM   #1
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Question Rear Window Removed, Some Rust Spots
I have removed my Rear Window to install a Slider Window. The inside is in perfect shape. However, on the outside there are 3 areas starting to rust.
What should I do about this, if anything at all? Meaning is there anything I could do to just stop/protect these areas before installing the Slider?
Thanks in advance for your thoughts / help.
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
Old 01-09-2022, 04:09 PM   #2
Re: Rear Window Removed, Some Rust Spots
Tape off around it , then lightly sand it and brush on some rust convertor/inhibitor stuff like POR etc....
Palf70Step is online now   Reply With Quote
Old 01-09-2022, 04:13 PM   #3
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Would this work to just "fix" these areas?
POR-15 Stop Rust Kit
Richard
Old 01-09-2022, 04:20 PM   #4
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Would the lightly sanding & POR-15 be enough or that kit I posted about is better (or over kill)? I also saw a POR-15 "Silver" by itself (along with Black POR-15 by itself too).
Richard
Old 01-09-2022, 04:58 PM   #5
sick472
sick472's Avatar
Your rust spots are not much to be worried about...they're small and just enough to pop the paint, AND the gasket will cover up the quick repair. POR-15 (or similar) is probably overkill, but, if done correctly, is certainly the best you can ask for.
If it were mine, I'd carefully sand the rust spots until they were shiny steel (no rust color left - maybe even use a small sand blast unit, probably overkill). The tape idea from Palf is a good one for the sanding, especially where you might over sand and get into paint that will be exposed after the back glass and gasket are installed. After sanding, I'd re-tape, hit it with some self-etching primer, let dry, hit with some gray primer, dry , then brush on a heavy coat of "something" like rustoleum, industrial enamel, or tractor paint...whatever that can be brushed on and counted on to last.
Before you go the extra effort in using POR 15 (or similar)...make sure you read the instructions...that stuff works and works well...if and only if you do it per the instructions.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 01-09-2022, 05:21 PM   #6
I am a fan of Eastwood Rust Encapsulater. Much easier to use than POR, but both as well as other brands will work. Just clean it and put something on it to keep it from getting worse.
Old 01-09-2022, 06:29 PM   #7
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
I went with that kit, it is MUCH smaller that the photo lead you (or me) to believe - it is just the right size. Though I will have TONS left over, I doubt I am using even 1% of it. Neither O'Riley's or AutoZone had POR-15 but Advanced Auto carried the kit - $31 and some change. I call that a good deal for peace of mind ;-)
I opened each "rusty" area with a poking tool, to get loose paint up. Just kind of felt how tough the paint seemed to be and then stopped. None of my poking felt like the rust got very far down, the metal seemed solid.
I am on stage 2 right now and letting that metal prep stuff do its thing for 20~30 minutes. Then I'll put the two light coats of POR-15 on. Then call it done. The rubber seal will cover all of this POR-15 patching.
Richard
Old 01-09-2022, 09:27 PM   #8
Getter-Done
Getter-Done's Avatar
If you have any left over that you want to reuse,
Put saran wrap between the lid and the can.
This will let you open the lid again.
If you don't it will seal itself shut.
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 01-09-2022, 09:43 PM   #9
jumpsoffrock
Probably the most valuable advice this thread has to offer.
jumpsoffrock is offline   Reply With Quote
Old 01-09-2022, 09:56 PM   #10
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
That is pretty intense paint! Thank you Getter-Done for that tip, just went out to the garage to do just that (would have never known)!
I have two coats on and got the tape pulled off. Looks like someone dropped a few black Chiclets on the edge of my window seal ;-)
Hopefully I can get the neighbor to help on the outside, while I pull the rope from inside tomorrow when he gets off work to get the Slider Window installed. He was going to help me today but I got derailed with the POR-15.
Richard
Old 01-10-2022, 08:35 AM   #11
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
This is how the driver side came out after scrapping to good metal and then doing the 3 stage POR-15. Seems nice and dry this morning, so hopefully I'll get in the slider tonight when I have a helper.
Richard
