Old 12-29-2003, 01:00 AM   #1
98L150
///Relaxed Atmosphere
98L150's Avatar
1st gear w/ 700R4 in 72 Sub
I am inthe process of installing a new crate motor and 700R4 in my 73 sub w/ factory tilt column. I am haveing problems getting the tranny in 1st gear. Has any one else have this prolem? If so what was done fix it?
Jeff
98L150 is offline   Reply With Quote
Old 12-29-2003, 02:47 AM   #2
Rooster's 67
Rooster's 67's Avatar
your factory column is for a three speed..you got four either swap the column or modify the linkage to get the extra "throw you need" but the pointer wont be correct.
someone has to have a better answer.
I personally put in a later model column
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 12-29-2003, 09:24 PM   #3
nate68
you have to modify it slightly to get it to go into 1st on the stock column. they don't like up right on the indicator but i dont have a problem with it cuz i know what gear i'm in
you have to take like 1/8" off of the *detent* (or something like that)
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 12-29-2003, 10:54 PM   #4
ckhd
ckhd's Avatar
'72 or '73? You say both.
I chucked the stock linkage in my '72 'burb. I used an aftermarket linkage that was adjustable on both ends, and it had an adjustable throw. I have no problem whatsoever with the stock column putting it in any gear I want to. The pointer doesn't line up, but I plan on changing that when I put my early 80's van tilt column in, and I'll find an indicator for a late 80s whatever with an overdrive.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
