![]() Join Date: Jun 2012
WTB Scottsdale Door Panel Inserts
WTB 81-87 Scottsdale door panel inserts like these. Thanks for the picture Keith!
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
Re: WTB Scottsdale Door Panel Inserts
if you talking about upper inserts wo/chrome If there still made the same any of the chromed one you just peel off the stick on chrome and you have the Reg black option ones. On factory ones, and If some one have one that LMC that broken badly scratched just peel off and we should find out. If you have a new set use a little heat take your time do not bend you can re use them on others sell.
I hope this helps you and other.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bedWas a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
Interesting. I have a set of old repop chrome ones and i will give it a try. Thanks for the tip!
| Bookmarks |
