Old 01-14-2022, 01:03 PM   #1
skip99
skip99's Avatar
Locking bearclaws
Ive been asked to post this, hope it helps
https://youtu.be/WE8R9bSUCvc
Tami's 51 build
http://67-72chevytrucks.com/vboard/s...d.php?t=428878
skip99 is offline   Reply With Quote
Old 01-14-2022, 04:44 PM   #2
FamilyTruckster65
Re: Locking bearclaws
Thank you for showing this!
FamilyTruckster65 is offline   Reply With Quote
Old 01-21-2022, 11:00 PM   #3
Dan in Pasadena
Dan in Pasadena's Avatar
Hmmm.... so only have to slot that hole slightly and it locks from inside, though it can't be unlocked from outside. Driver must slide over to unlock passenger door.
OR, put a driver's side push button lock in ('55-'59's without any modification) and it CAN be locked/unlocked from outside. Have I got this right?
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 01-22-2022, 12:00 AM   #4
skip99
skip99's Avatar
I did both, able to lock from inside, and use a key onboth doors
Tami's 51 build
Old 01-22-2022, 08:52 PM   #5
bosco
bosco's Avatar
Wink Re: Locking bearclaws
I installed two exterior locks. I didn't like reaching over to unlock, plus I look more gallant opening the door for my wife.
bosco is offline   Reply With Quote
Old 01-22-2022, 10:00 PM   #6
fauXGT
fauXGT's Avatar
With a little reverse engineering, and wanting to put in new not worn out latch mechanisms along with a drivers side lock, I tore appart the old passenger side latch that held the locking part. Omitted from the drivers side so it was easy to figure out. Then opened up the new driver side. The new driver side, with a bit of tinkering and welding, could hold a 180deg reversed locking mechanism. A bit of micro-cutting and welding/filing later, a dry fit works the same as the passenger side. A complete opposite of the passenger locking piece. Can lock/unlock from inside and outside like factory passenger. Now have to find a local locksmith to re-key a single '51 lock to match the rest.
fauXGT is offline   Reply With Quote
