Old 01-14-2022, 01:17 PM   #1
Tx70Gmc
Tx70Gmc's Avatar
Rear-End Identification help
Can anyone help identify my rear-end?
I posted a reply in a very old thread, but did not have any luck getting responses, so I figured I would try to post a new thread.
I have searched the forums and came across a post that referred to some identifying factors, but I'm not sure what it all means.
here is the post:
http://67-72chevytrucks.com/vboard/s...79#post9018479
Can you help me identify mine?
67890 - GM 12 bolt
E120 - May 12, 1970
NF3896838
Axle Stamp = TDA 0521W1
so I think the TDA means its a 3.73 gear and I think the 052 is the 52 day of the year it was built? and I have no clue what the 1W1 means?
any ideas?
Thanks,
Tx70Gmc is offline   Reply With Quote
Old 01-14-2022, 06:00 PM   #2
MikeB
MikeB's Avatar
Re: Rear-End Identification help
Yes, TDA on a 1970 rear end means 3.73 gears. Funny, but on 1971 models TDA means a G30 van with 4.57 gears.
I didn't spend a lot of time searching, but can't find anything on 0521W1.
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 01-14-2022, 06:40 PM   #3
Getter-Done
Getter-Done's Avatar
I did not find the 0521M1 either.
I did find this in the link below.
Link: https://www.chevyhardcore.com/tech-s...rearend-guide/
The early bird gets the worm,
84 Chevy K-20
Old 01-14-2022, 06:57 PM   #4
Tx70Gmc
Tx70Gmc's Avatar
I read that entire article and it helped with date code, etc but not the 0521W1
Old 01-14-2022, 07:08 PM   #5
Getter-Done
Yeah
There is lots of info for cars.
I tried using different search words to dig a little deeper for truck stuff
Maybe someone will know the answer
84 Chevy K-20
Old 01-14-2022, 10:19 PM   #6
BigBird05
Mike B 71 is a different axle than a 70.
BigBird05 is offline   Reply With Quote
Old 01-14-2022, 10:48 PM   #7
BigBird05
I am looking at it a different way. 0521 is May 21st day, W is the plant that assembled the axle, 1 is first shift.
Old 01-15-2022, 12:01 AM   #8
Tx70Gmc
Tx70Gmc's Avatar
Maybe your on to something.
The pumpkin has the code E120, which was May 12,1970
And maybe the axle was made on May 21, 1970?
Would that make sense?
Old 01-15-2022, 05:32 AM   #9
MikeB
MikeB's Avatar
How so?
Mike
Old 01-15-2022, 06:59 AM   #10
BigBird05
Originally Posted by MikeB View Post
How so?
Tx70Gmc, The pumpkin code is cast into it, the axle code is stamped.
Mike B 70 and 71 axles are a different width. I think the 71 is wider by maybe an 1 inch.
Old 01-15-2022, 10:58 AM   #11
uncle
Is the rear axle a five or six lug. What year is your truck? About 95% of the 70 model trucks that I’ve had had the same width housing as 71 and 72. I’m not saying they all do but most that I’ve experienced have.
uncle is offline   Reply With Quote
Old 01-15-2022, 11:02 AM   #12
uncle
I probably didn’t read all the above post very carefully but here’s a post from a board member years ago as far as the code and gear ratio.
Old 01-15-2022, 11:04 AM   #13
uncle
Pic
Old 01-15-2022, 01:23 PM   #14
MikeB
MikeB's Avatar
I know GM went to a wider width on the 70 models, but possibly not the earliest ones off the assembly line. And I think 71-72 rear ends were the same width as 70, but starting in 71 they went to 5-lug axles.
My 69 really looked goofy with its narrow rear end, even with larger 235 tires. Finally went to 255 tires on 8" Rallys which fill the wheel wells perfectly.
Mike
Old 01-16-2022, 08:21 AM   #15
BigBird05
5 lug axle length is 31 7/16, 6 lug is 30 3/4.
Old 01-16-2022, 11:43 AM   #16
MikeB
MikeB's Avatar
Mike
