12-29-2003, 03:15 AM | #1 |
Garage Queen Material
still aways to go
Hedman Elite shortie headers (1 5/8" , 3")
harmonic balancer flexplate Harland sharp Roller rocker-arms electric fans water pump(electric or mechanical???) fuel pump(electric or mechanical???) holley 750cfm carb vac. secondaries(3310) MSD street probillet distributor msd blaster2 coil msd 6al ignition New starter new alternator new torque conveter(if i can find one) tranny cooler all the stuff i still will need to purchase, after i get the shortblock done. although i do need to get the balancer and flexplate before its done so that he can balance it. |
12-29-2003, 04:10 AM | #2 |
Hotwheels?
750 might be a tad too much, but I dont know with 400+ HP.
1978 Money Pit - CUSTOM DELUXE!!!! |
12-29-2003, 01:34 PM | #3 | ||||||
driving is in my blood
Re: still aways to go
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
12-29-2003, 02:15 PM | #4 |
Why a new starter and alternator? Your old ones should work. I would also second the electric fuel pump. Run the Holley red pump and you should be fine.
Tom, on the converter, he has the TH350 TC with the lock up on it.
Gary -1986 SWB: lowered 4/6, SOLD!!! -Best 1/4 mile: 14.51 @ 91.01 MPH -2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!! -2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels |
12-29-2003, 02:19 PM | #5 | |
12-29-2003, 02:22 PM | #6 | |
Workaholic
12-29-2003, 02:22 PM | #7 |
Trucker.
Might try Phoenix Transmissions in Weatherford, TX. They do tons of stree/strip TC's and build them all in house.
http://www.phoenixtrans.com/ |
12-29-2003, 02:40 PM | #8 |
yeller
Man you guys, there are cars that run 9's..on mechanical fuel pumps (although not "stock" ones)...there is no need to run an electric one. They take more work to install (plumbing and wiring), and if it fails...you have to try and find another...whereas any mayor parts store will have a mechanical on the shelf. Not only that, but Holley elec pumps suck! They are noisey and tend to chew themsleves up on a regular basis. If you are determined to run an elec pump, get a aeromotive, mallory, or a good name brand pump. On the water pump, mechanical for sure...electric pumps are typically for racing applications.
Eric, don't mean to offend you by this, just simply going by my personal experiences. All the stuff on your list will add up quickly and cost a good amount of money. If you are anxious to get the truck running and driving again, buy only the stuff you really need at the moment...and upgrade to the expensive stuff later. Do you really need a new starter, distributor, alternator, etc...? Lack of money can kill a project and ruin motivation to finish it. Either way, good luck, and keep us posted.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
12-29-2003, 02:49 PM | #9 | |
12-29-2003, 03:01 PM | #10 | |
yeller
12-29-2003, 03:08 PM | #11 |
Water pump, Mechanical for sure, electric ones cant handle daily use and you DONT want that thing to quit working one day while you are driving.
Fuel pump, I would go mechanical. I have a mechanical on my truck and an electric on my wagon and the electric one is an annoying pain in the ass. If your gonna drive it alot, mechanical. I WOULD dump the cash on all MSD ignition including the dist. Every motor that I have built with MSD stuff has been a whole lot easier to initially start and tune. MSD on a brand new motor will start within 2-3 cranks for me usually. I will live and die by their products. I would also step down to a 650 carb. The only smallblock I have played with that needed a bigger carb then that was our impala, however the 355 in it was putting out near 500 hp. You shouldnt need that much. Other than that you list looks good, the tranny cooler is a must, plus you dont have to deal with the ugly tranny lines from the radiator back. Just my .02
Daily Driver: 1992 Blazer dropped on rallys Project: 87 GMC shortwide, About to get a little boost |
12-29-2003, 05:45 PM | #12 | |
Re: Re: still aways to go
1,600-1,800 rpm stall speed with a small block and the superstreet fighter is: 3,400-3,600 rpm stall speed with a small block anything inbetween? |
12-29-2003, 06:32 PM | #13 |
1. Get a mechanical fuel pump (140gph). I run a Carter 170gph on my 550cu with 650hp. Electric pumps blow! Holley electric pumps blow! I've had both and mechanical pumps don't fail.
2. Get an mech. aluminum waterpump. Keep it simple! 3. Stay with a 750 vacuum sec. If your gonna go for the 425hp or more it's perfect! I liked the edelbrock 750 on my 383/450hp, it ran a tad rich but that's fine. 4. Get the MSD Pro-billet HEI and your done. No box needed. Keep it simple! 5. Get a converter that stalls between 2500-2800. This will let you cruise with your truck and not heat up the converter. I put in a big B&M trans cooler right in front of the radiator (passenger side) with 2 pieces of 1" alumnum across the opening, looks factory! 6. The Hedman Elites are a nice choice. And yes 1 5/8" and 3" is perfect. You will love em! 7. If you still have money- Go with the 1 wire 140amp Powermaster alternator and eliminate all the extra wires in the harness. Should still be on Mikes old website. Jeff's 73-87.com. I also went with Powermaster's mini-starter that has adjustable mounting holes and I'm totally satisfied
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction |
12-29-2003, 10:42 PM | #14 | |
Workaholic
Re: Re: Re: still aways to go
Part number PP3530 $175 I can't say anything about the quality because I have never used them. |
12-30-2003, 01:29 AM | #15 |
I'm curious about the full roller rockers the more moving parts the easier something can mess up. What lift does the cam you plan on running.
I have Comp Cams magnum roller tip rockers on a cam with a .564 lift and havent the first problem and they were alot cheeper too. The electric pump aint nothing but a pain in the a$$. I finally got rid of my Holley Red cus it sounded like a pissed off coffiee grinder under my truck. Got the Holley 110 series and I carry 5-7psi all the way 6000rpms If there is one thing I have learned is KEEP IT SIMPLE so you can spend more time behind the wheel instead up under the hood. Just wished I had all the money I have blown on OVERKILL |
12-30-2003, 02:20 AM | #16 |
cam specs:
Intake valve gross lift/duration: .490"/290° Exhaust valve gross lift/duration: .490"/297° Intake valve duration @ .050": 235° Exhaust valve duration @ .050": 240° Rocker arm ratio: 1.5 Intake valve lobe centerline: 107° Lobe separation: 112° |
12-30-2003, 02:21 AM | #17 | |
Re: Re: Re: Re: still aways to go
thanks, i'll have to lookup on that. kinda weary on it though, considering the price |
12-30-2003, 05:49 AM | #18 |
Available for Adoption
I'm with Jeff, keep it simple... scratch the elec fuel pump.....I don't think there is an easier mech fuel pump to install than a SB Chevy, got 5 minutes?? With this being a daily driver, I would really be careful about getting to radical, you'll hate it, trust me, where you going to get parts on a Sunday afternoon so you can get to work/school monday morning??.... Personally, I like MSD ignitions, but do your homework.....I've spent alot of years building hot rod Harley's (concept is no different than this) and ignition systems is where I saw the most money wasted....The air/fuel mixture is only going to burn SO fast no matter how much juice you put to it. The key is finding the correct ignition curve, keep it simple...
Just my opinion, probably the same as many others, I would run away from anything that said TCI or B&M...Take the money you'll save on the water pump, fuel pump, ignition, alternator and starter and buy a GOOD converter, Hughes Performance, they aren't cheap but they are worth it....get the tranny cooler, you already need it.... Carb, I would probably stick with a 650 dbl pumper, 750 seems a little overkill for a 350ci engine, I guess this is debatable.... Some other things that may seem small but are going to add up and always sneak up on you.... 4 core radiator or at least a professional cleaning-I wouldn't want that old crap running thru my new motor... motor mounts-tranny mount-now is the time for new ones 10qts of engine oil and 2 filters-initial start up and break-in new hoses and belts-nows the time new tranny filter and oil to go with new TC and cooler distilled water and anti freeze How old are you battery cables?? pvc, fuel hoses, etc etc etc...... Maybe I'm a little anal, but if I have everything out and apart, NOW is the time to replace it, not right after I get it all back to gether and it breaks.... Have fun, new motors are always alot of work, but alot of fun in the end....I'm exited for ya and it's not even mine...
1983 C10 SWB 2001 Silverado SWB 1995 Corvette |
12-30-2003, 10:20 AM | #19 | |
anyways, i'm the same way, i'm gonna be replacing all those small parts. radiator is gonna be flushed good, and the hoses and the tranny/motor mounts are gonna be replaced also |
12-30-2003, 01:11 PM | #20 |
Hughes could build you a nice 2500 stall convertor if you ask them nice I know them well from my dealings with getting a built tranny made for honda v6's.
12-30-2003, 04:17 PM | #21 |
I agree with Tom, 2500 would be about right....it won't be cheap, especially with the lock up, but it'll be a good TC....
Oh yeah, I think this is finally my 100th post....has taken awhile, I guess I should post more......mostly just lurk....
12-30-2003, 06:39 PM | #23 |
If you're a 700R4, then I would suggest a Yank Torque Converter. I have a Yank in my vette, stalls to 2600, and it's very streetable.
01-04-2004, 01:18 AM | #24 | |
For instance stock motors Idle around 500 to 550 RPM, the torque converter stalls at around 800 or so. since stock cams build power off idle, your 300 or so RPM into the powerband when it stalls. the more radical the cam the further the gap needs to be, but for street driving driving I would never go for more that really 900 RPM over, unless your going to drag race every weekend. I don't know the specs, but unless your cam is really radical. It probably starts to build power at 1500 RPM. So a 2300 to 2500 stall is what you would need. Even at that pulling out on a hill during daily driving you will have to torque your motor up that high just to normally drive. Have planned out your intake it also should match your cams powerband for the best combination. but like I said just my .02 |
01-04-2004, 02:27 AM | #25 | |
http://www.holley.com/HiOctn/ProdLin...K/300-503.html
thats the kit i have. the intake, heads, and cam all match up great together(or so they say). they also RECOMMEND a 3000 stall with my tranny. Quote:
