01-18-2022, 01:21 AM | #1 |
Tailgate Band Placement
I would like to document the placement of the woodgrain tailgate band that were found on the CST, Cheyenne, Cheyenne Super, Sierra, or Sierra Grande trim packages.
I am curious to determine if there are any patterns that might explain the variation in the band's placement such as build factory, build date, etc. Maybe there is no pattern at some plants and more of a pattern at other plants. At first glance, it appears that some bands were mounted flush with the "stamping line" and other were mounted up to an inch or more below. Feel free to post any pictures, but I would like to see the following included: 1) original paint tailgate--restored examples aren't as definitive, as they could be aftermarket tailgates. 2) a partial VIN number showing at least the plant letter code plus the three following digits, ie. CCE242S138xxx. A SPID is most desirable, as it would also confirm the trim and paint options. Summary List: Baltimore Chevy 9B835860 - Offset (post 3) Truck Flint Chevy 1F654299 - Offset (post 2) Blazer Janesville Chevy 1J633548 - flush (post 4) Truck St. Louis Chevy 1S649xxx - Offset (post 6, 8) Blazer 1S659169 - Offset (post 3) Blazer 1S661995 - Offset (post 5) Blazer 2S102300 - Offset (post 5) Blazer 2S103440 - Offset (post 4) Truck 2S115357 - Flush (post 4) Truck 2S123430 - Offset (post 3) Blazer 2S157442 - Flush (post 1) Truck St. Louis GMC 2S513868 - Flush (post 3) Jimmy 2S516309 - offset (post 5) Jimmy Fremont Chevy 9Z833XXX - Flush (post 7) Truck 9Z835876 - Flush (post 4) Truck 0Z126935 - Offset (post 3) Truck 1Z630470 - Flush (post 20) Truck 2Z108075 - Offset (post 19) Truck 2Z131XXX - Flush (post 15) Truck 2Z175621 - Flush (post 4) Truck Fremont GMC ZZ59890 - Offset (post 2) Truck Last edited by 402Bowtie; 01-21-2022 at 01:29 PM. |
01-18-2022, 01:23 AM | #2 |
Re: Tailgate Band Placement
71 Flint Blazer - Offset mount. The ad states they think it is original paint, and the band looks to be OEM. However, the disc brakes sticker placement seems lower than most.
70 Fremont GMC - (significant) offset mount. |
01-18-2022, 01:32 AM | #3 |
69 Baltimore chevy - Offset
70 Fremont chevy - offset 72 STL Blazer - offset 72 STL Jimmy - flush 71 STL Blazer - offset Last edited by 402Bowtie; 01-18-2022 at 01:38 AM. |
01-18-2022, 01:40 AM | #4 |
69 Fremont chevy - flush
71 Janesville chevy - flush 72 STL chevy - Offset 72 Fremont chevy - flush 72 STL chevy - flush Last edited by 402Bowtie; 01-18-2022 at 02:07 AM. |
01-18-2022, 11:45 AM | #5 |
Appears to be original paint 72 STL blazer - offset
71 Blazer 1S661995 - offset 72 Jimmy 2S516309 - offset Last edited by 402Bowtie; 01-18-2022 at 04:06 PM. |
01-18-2022, 01:21 PM | #6 |
67-72 parts collector,…
My ‘71 2wd blazer is original paint.
This is the only tailgate band pictures I have. It’s offset. Also the “disc brake” decal placement.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 01-18-2022 at 01:31 PM. |
01-18-2022, 01:26 PM | #7 |
Thanks! Would you be willing to provide the next 4 digits after "181" in your VIN? Or at least the plant letter code?
01-18-2022, 01:31 PM | #8 |
It’s S649 after the 181
01-18-2022, 03:22 PM | #9 |
My '69.
VIN CE249Z833XXX. Original tailgate, band, trim and holes. First picture is also original paint.
Jim Last edited by FirstOwner69; 01-18-2022 at 05:09 PM. |
01-18-2022, 03:38 PM | #10 |
Thank you both!
01-18-2022, 03:45 PM | #11 |
Carpe manana
Interesting. I'll follow.
Will mention that 72 Blazers made use of bright trim below the band: http://67-72chevytrucks.com/vboard/s...d.php?t=699985
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
01-18-2022, 04:24 PM | #12 |
My guess is that as long as it was in the general area that it was acceptable...It probably depends on whether it was Joe Blow or John Doe that was installing them that day....
trying to find rhyme or reason from 50+ years ago may be the proverbial "needle in a hay stack" here is the factory dimension as shown on the drawing....
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
01-18-2022, 04:49 PM | #13 | ||
That drawing doesn't show what the resulting offset would be between the top edge of the trim and the stamping line. I have an original (Fremont) truck and tailgate at home with the band removed. There are some wear lines that show its band was flush mounted originally. I'll measure the holes to see if matches the assembly manual...and I'll get some pics. Do we know what the 2.12 dimension references? I can look at my manual... |
01-18-2022, 05:50 PM | #14 |
There have been some threads about different tailgate stampings.
This one https://67-72chevytrucks.com/vboard/...d.php?t=494219 shows that the ends of the recessed area below the tailgate handle varied. Perhaps the horizontal recess below the handle was also a bit wider top to bottom on depending upon the stamping. That would make sense since all dimensions in the assembly manual for the band location are from the bottom of the gate which would make the the band appear to vary in location. Here's a thread that also discusses stamping differences, but I think all these are on the inside of the tailgate. https://67-72chevytrucks.com/vboard/...d.php?t=523850
Jim |
01-18-2022, 08:15 PM | #15 | |
The second link you posted is pretty thorough IMO. From what I have seen, there are three tailgate stampings: 67, 68-69, and 70-72. Since the band was first available in 69, your theory could be true for differences in 69 vs 70+ gates (although I'm skeptical), but the 70-72 gates I think are identical stampings. I don't mean to shoot your thoughts down, but just thinking out loud some too and sharing what I've seen. Pictured below is a 2Z131 Cheyenne truck. The wear marks show it as a flush mount. And the bottom screw measures 2.75" from the most-bottom edge. |
01-18-2022, 08:29 PM | #16 | |
Do we have any idea if the holes were pre-drilled or drilled on the factory floor? I'd assume at the factory. If so, I wonder how. A jig of some sort? A pattern?
Jim |
01-18-2022, 10:36 PM | #17 |
It would make sense that a jig of some sort was used, whether provided by GM or fabbed by the installer.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
01-19-2022, 09:55 AM | #18 |
Carpe manana
Self tapping screws but I bet a jig or some device was used to position the band.
01-19-2022, 01:16 PM | #19 |
here's the tailgate band on my original paint 1972 cheyenne super,built at the Fremont,Ca plant,Sept 1971
01-21-2022, 01:32 PM | #20 | |
Here's a 71 Fremont 1Z630470 - Flush |
01-21-2022, 01:40 PM | #21 |
Have not read all post but my perception and what I feel is the best look is just below the top center stamp line. To me when right online it doesn't give it depth when looking at it dimensionally.
01-22-2022, 09:52 PM | #22 |
So at this point it appears they just slapped on the band wherever. Any more examples? Here's a St. Louis example that appears to be flush.
