Old 12-29-2003, 11:43 AM   #1
bagged81
Signals in the bumper.
bagged81's Avatar
Rear swaybar and bags?
Is it possible to have both? That is, utilizing a straight swaybar bolt-on kit.
Jeff C.
1981 Chevrolet Silverado - Under major construction...again. link
1962 Chevrolet Impala 4D Sedan moredoorclassics.com
1936 Ford Pickup - Frame-off in progress link
1979 Chevrolet Camper Special Flatbed link
bagged81 is offline   Reply With Quote
Old 12-29-2003, 12:51 PM   #2
Izzy
Trucker.
Izzy's Avatar
I would think there will be way too much flex if you're playing with the bags out back.
Izzy is offline   Reply With Quote
Old 12-29-2003, 01:25 PM   #3
bagged81
bagged81's Avatar
Thats what I was thinking too.
Jeff C.
Old 12-30-2003, 08:43 PM   #4
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
It would work as long as you don't want to do any side-to-side movement. I'm pretty sure you could redo the links on a swaybar so that it wouldn't bind as it moved up and down (since there are different styles), but good luck going side-to-side, unless you disconnect it.
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
Old 12-31-2003, 01:59 PM   #5
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
If you wanted to play with it, you could figure out a way to implement some sway bar disconnects like the offroad guys use. I am just thinking aloud for you.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
