metal bed bolt up
Does a metal bed floor on a 1968 c10 sit Directly on the frame in some parts ? Im going from wood to metal and not sure if im missing anything
![]() Join Date: Mar 2003
Re: metal bed bolt up
Yes, sometimes there was a thin rubber pad to keep it from squeaking, kinda like a flattened out inner tube
![]() Join Date: Feb 2009
Interesting. They sell rubber pads, I mentioned it to a guy who's built many of these and he says don't use them, reason being you're reducing a proper ground. Who knows, might work either way so long as there's a ground strap to the frame or so. All I know is I made and installed some, but I have to shim the bed in a spot or two and will probably remove them.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
I used rubber pads on my metal-to-wood conversion. You should definitely add some grounding straps. Chances are the bolts would ground the works, but they tend to rust and loose the ground. Not to mention those bolted connections are usually well painted to begin with, whereas properly done straps will maintain the connections. I put two straps on between my frame and bedsides. One on each side at the rear. This helps ensure the taillights work well.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
![]() Join Date: Aug 2019
As grounds go I always add a ground wire to all of my harness's and install the factory ground straps. When I have a electrical problems it is not the ground.
#6 | |
