01-18-2022, 10:27 PM | #1 |
4wd all rubber upper radiator hose
I can't find the thread, but I thought I remembered that someone was reproducing the upper radiator hoses for 4wd's that were all rubber (without the steel piece in the middle). These were molded to correct angles and not the "flex" style generic hose. Any thoughts? Thanks
01-18-2022, 10:37 PM | #2 | |
All about them K’s
Re: 4wd all rubber upper radiator hose
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
01-19-2022, 10:53 PM | #3 |
When I bought my gmc it had one of those generic accordion style hoses on it. Pissed me off just looking at it. I replaced it with a one piece upper hose from O’Reilly. Gates PN 20607 for 4wd with 350 engine. Sorry about picture quality, I just went out and took the pic in the dark.
1972 GMC K2500 Super Custom Matt |
01-19-2022, 11:06 PM | #4 |
I actually went to AutoZone a couple of times and just told them my application and it was the hose your looking for
01-20-2022, 10:24 AM | #5 |
I got mine from RockAuto. They list quite a few different brands.
01-20-2022, 10:57 AM | #6 |
It is Wes at classic heartbeat pickup parts
atheystruck@comcast.net 67 1/2 ton 4wd custom cab 72 1/2 ton 4wd super cheyenne 71 1/2 BB super cheyenne shortbed |
01-20-2022, 11:06 AM | #7 |
Thanks for the responses. I have a Blazer and I'm finding out most of the part search engines from any of the chain stores, or even Rock Auto don't include an option to select 4wd. Most parts show up as 2wd or RWD. So, I have changed and started selecting K10 pickup, and now parts clearly show up as required for 4wd. I see the 4wd hoses now on Oreilly and Rock Auto.
01-20-2022, 01:45 PM | #8 |
I kinda like the radiator "pipe". People look at you funny when you say radiator pipe - until you show them.
Plus if one of the ends blows out while you're on the road, finding a straight piece is easy.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
01-21-2022, 08:06 AM | #9 |
I think I'll upgrade mine to the later molded one piece. My thoughts on this are it's better to have two ends that might leak than four. Also, the 1pc hose gives better flex. The joints between pipe and short stiff hose get stressed when flexing occurs. As with all other vehicles, routine maintenance will all but eliminate hose failure. Belts and hoses at the same time. These are good things to carry spare, when in doubt. I'll set the OEM on the parts shelf in case one day being 100% original matters. I agree, it has been neat having the conversation piece and all you need is a short piece that fits in the glovebox.
01-21-2022, 08:54 AM | #10 |
Me, too, and for similar reasons. Never had an end leak on the upper.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
