Old 01-20-2022, 12:53 PM   #1
67ss&99ss
Andy
Question seat lowering brackets
For those of you that have installed seat lowering brackets, were you able to retain the gas tank in the factory location, or is it mandatory to relocate the tank? I don't see this information posted on Brother's site or the Full custom fab site. I assume these are currently the only mass produced options for lowering the seat? My line of sight is too high through the windshield and I will be doing a conversion from auto to manual so i want as much room and to be as comfortable as possible driving my truck. I want to be able to daily drive it or take it on trips.
https://full-custom-fabrication.squa...rue&cst=custom
https://www.brotherstrucks.com/1967-...tinfo/LSB6772/
1967 Camaro SS 406|522hp/514ft lbs|M20 Muncie|3.73s|Posi
1969 CST/10 383|Aisin AR5 5 speed
1972 K5 350|Turbo 350 4x4
2005 Duramax 2500HD 4x4
67ss&99ss is offline   Reply With Quote
Old 01-20-2022, 01:01 PM   #2
northerngmc
northerngmc's Avatar
Re: seat lowering brackets
I just installed the FCF in my 68 this winter. Factory tank is in place without an issue.
I have not driven it yet so I can't say if I like it or not. Currently pushing the steering wheel ahead by collapsing the column an inch.
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 01-20-2022, 01:12 PM   #3
MikeB
MikeB's Avatar
I was looking at the brackets, but decided that lowering the seat with a non-tilt column would put the steering wheel too high. Also, if you're taller than 6ft or so, your knees would be up higher. I'd want to try before buying.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 01-20-2022, 01:26 PM   #4
MikeB
MikeB's Avatar
Hey Blain, I did that on my 69 a few months ago, but messed up the neutral safety/backup light switch by essentially pushing it into the firewall pad. I plan to remove the column to see if I can cut a hole and mount a new switch a little farther away from the pad. Seems like one of the members here said it's easy to do.
Also, if you have a full-size 3-3/4" column-mount tach, it may have to go. I found an AutoGage #2300 that is approximately 3/4" less deep than the SunPro tach I had on the truck for 30 years. The old tach was no longer accurate, so it had to go anyway!
Mike
Old 01-20-2022, 01:55 PM   #5
northerngmc
Yeah I pushed the neutral safety switch up to the firewall. It doesn’t seem to be working. I need to drop the column down and check my wiring. You only get about 1” without moving the switch. No tach for me! The 396 only winds up so much!
Blaine
Old 01-20-2022, 03:05 PM   #6
MikeB
MikeB's Avatar
Ha! Glad to see I wasn't the only one to do that!
My switch may not be broken, but it's probably 53 years old, so I bought a new one.
Mike
Old 01-20-2022, 03:14 PM   #7
72c20customcamper
72c20customcamper's Avatar
While the shorty tilt is much nicer than the stock column I didnt have a problem with the stock column with the lowering brackets drove it for 2 years before I got the new column
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 01-21-2022, 09:40 AM   #8
67ss&99ss
Andy
Thanks for the feedback everyone.
Old 01-21-2022, 02:13 PM   #9
68Stepbed
68Stepbed's Avatar
Plan a trip to Pigeon Forge, TN, and I'll let you sit in mine with the FCF brackets.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 01-21-2022, 04:30 PM   #10
AllGoNoShow
I’m 6’3 and the FCF brackets put me in a much better driving position (mine is a manual with stock column and everything inside in stock location). I didn’t like the idea about only using half of the original bolts to mount the seat so I actually bought 2 sets of these and installed them 2 on each side so all the original bolt locations are used.
AllGoNoShow is offline   Reply With Quote
Old 01-21-2022, 04:45 PM   #11
typerr
I have a pair of the full custom mounts but after using them for a year I'm going back to stock. On my 5-speed truck I don't like the angle to the clutch pedal with the seat lowered. I'm only 5'-6 tall and to be honest I have no idea how tall guys drive these trucks!
typerr is offline   Reply With Quote
