Will my guage handle it?
I started my truck up for the first time with the original guagues in it. My oil pressure guaged was pegged as far as it could go. I've got a built 400 sb. with a high volume and pressure oil pump in it. My concern is that my factory guage won't be able to handle the pressure since it was already close to being pegged just lettin the motor idle. A burst oil guage would definately hurt my feelins and my new interior. Anybody else had a problem?
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
My toyota run's 65 hot and the guage is pegged when cold (10 w 30) auto guage BTW
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
I would be concerned about the gauge since it is probably a 60 psi gauge.
Try hooking up a 100 psi gauge to see what the actual pressure is. I believe that 80 psi gauges are available and that might do it for you. Jim |
that pump is probably putting out 80 psi most do and they have a pressure release at 80 but if it was me i would change the gauges to autometers with a 100psi oil guage
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
Wiseass secured himself a BAN
I would change to an aftermarket gauge also.
please don't break
haha i have the same problem. i have a built 350 and at idle it's pegged and as it comes up off idle it goes off the chart. probly ought to fix that
same here.....
but were driving chevy's not fords...... ![]() most parts are good for double the working pressure...... mine come's off the the high side once it's warmed up IT'S ONLY MONEY...... ![]() |
