01-22-2022, 05:43 PM | #1 |
12 bolt upgrade to posi parts list
Gents,
a few years ago i upgraded my rear end to all new parts and added a Eaton Posi unit. and ever since I have seen a few threads where other members have been asking about part info on doing the same . Today i just happen to find my parts list on my computer and thought i would share in case anyone is looking or interested. remember the truck 12 bolt is not quite the same as a car 12 bolt. and I have a series 4 carrier all parts where ordered from www.summitracing.com and their part numbers are listed below Yukon Gear & Axle YA G14071751 - Yukon Gear & Axle Rear Axles Detroit Locker 913A315 - Eaton Detroit Truetrac Differentials Motive Gear GM12-373 - Motive Gear Ring and Pinion Sets Yukon Gear & Axle YK GM12T - Yukon Gear & Axle Master Overhaul Kits Yukon Gear & Axle YSPCC-010 - Yukon Gear & Axle C-Clips Dorman 610-138 - Dorman Wheel Studs Limited slip additive Yukon YGA-15018 Gear Lube, Heavy Duty Plus, 80W90, Hypoid, GL5, One qt., Each Part Number: LUC-10043-1 QTY 2
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
01-22-2022, 08:58 PM | #2 |
Re: 12 bolt upgrade to posi parts list
Thank you, I have been looking to do this upgrade on my reared man did you just save me a lot of time
01-22-2022, 09:40 PM | #3 |
I just put in an Eaton Limited Slip differential. No issues so far but I regret not using the Trutrac instead.
01-22-2022, 10:16 PM | #4 |
Just an FYI as I have the same diff, but Detroit specifically says not to use the limited slip additive with the Truetrac (just use GL5 like Valvoline).
Posted via Mobile Device |
01-22-2022, 11:11 PM | #5 |
So did you do an Eaton Posi or a Detroit TruTrac? You say one but then include the part for the other.
01-23-2022, 12:00 AM | #6 |
And also check the year of your rear end,1970 only has different axle lengths,
01-23-2022, 12:16 PM | #7 |
I do not remember honestly I am pretty sure I did not go with the Detroit locker,
ETN-19556-010 here is the part number for the EATON Posi Sorry about that, this was several years ago, and summit does not let you archive past orders and they do not keep history for very long
01-23-2022, 12:35 PM | #8 |
Last time I upgraded to a posi case my parts list looked like this:
Posi case for the appropriate gear ratio Fluid and gasket but I am particularly frugal
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
01-23-2022, 01:50 PM | #9 |
I wanted to do a full upgrade and refresh across the board
01-24-2022, 12:56 PM | #10 |
bigmac73,
Was the studs you used a stock length? The reason I ask is that I converted over to rear dis brakes and need a 1/2 longer stud. Any recommended parts number would be appreciated. |
01-24-2022, 01:31 PM | #11 | |
I also installed the Wilwood rear disk brake set up and installed 20 inch wheels and tires. I just went with a longer shank on my lug nuts that go deeper into the bolt hole I am still working on the off frame resto so I have not had it out on the street yet
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks Last edited by bigmac73; 01-24-2022 at 01:54 PM. |
01-24-2022, 01:53 PM | #12 |
01-24-2022, 02:03 PM | #13 |
Mr. Cheyenne
good to see someone is doing well on their analog clock homework (and interesting art work too). ;-)
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
01-24-2022, 02:35 PM | #14 | |
honestly the kids today are lost when it comes to reading a clock or counting money. one small 15 min lesson and a worksheet in school is about all they get nowadays. And since the wonderful debit card invention. Counting change and handing coins is obsolete so kids are not exposed to money like when I was a kid.
01-24-2022, 06:15 PM | #15 | |
01-24-2022, 07:19 PM | #16 |
70+ ( Old Skool Club )
Curious as to your reason for thinking that.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
01-25-2022, 05:39 AM | #17 |
bigmac73,
Thanks |
01-26-2022, 02:38 PM | #18 |
