01-22-2022, 09:52 PM | #1 |
Dimmer Switch Wires?
Can Anyone Tell Me Which Wire Goes Where In The Dimmer Switch Connector? Thanks
Posted via Mobile Device |
01-22-2022, 10:51 PM | #2 |
Re: Dimmer Switch Wires?
I Had To Cut The Wires n Lengthen Them. Just Curious If It Matters?
01-22-2022, 11:09 PM | #3 |
The Older Generation
I'm presuming that the yellow wire is connected to the original blue wire. If so, it would go to the center terminal and the other two can go to either outside terminal it doesn't make any difference on them. LockDoc
01-23-2022, 12:29 AM | #4 | |
01-23-2022, 12:34 PM | #5 | |
What year is your truck? As far as I know '67 - '72 stock colors on the dimmer switch connector are Green, Blue, & Tan. In any case, whichever wire is hot with the headlight switch on (probably Yellow) put it in the middle and the other two, one on each side.... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 01-23-2022 at 12:40 PM. |
01-23-2022, 03:12 PM | #6 | |
Thank You. Exactly What I Needed. Their Top Lead Is Yellow. Thank You!! Posted via Mobile Device |
01-23-2022, 08:11 PM | #7 | |
No problem. LockDoc
