Old 01-23-2022, 01:48 PM   #1
mismith
Cracks in Hubcaps
I’ve got a nice set of Original ‘66 chrome caps but unfortunately one has a crack. I have some questions and concerns about using it. I know some of you may have dealt with this as well.
What’s the likelihood of this crack getting worse if I use it? I worry that I could possibly lose this one if I run it.
Would you attempt to repair it and if so, how? Would I be better off retiring this one to the wall and looking for another one with no cracks?
One fellow enthusiast suggested it would be ok to run it but I should place the crack in between the nubs on wheel. I don’t really think that would help myself but could be wrong?
I’ve thought of some repair ideas and open to suggestions. 1) Clean and strip the inside where crack is down to brass and solder or JB weld in a brass or stainless strip of metal across the crack. 2) JB weld in a strip of metal and drill and pop rivet with SS rivet on either side of crack. I’m afraid the heat would discolor the chrome if silver soldered?
Your thoughts and opinions welcome.
mismith is offline   Reply With Quote
Old 01-23-2022, 04:18 PM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: Cracks in Hubcaps
If you decide to run it, at the very least, drill a small hole at the end of the crack to keep it from spreading
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 01-24-2022, 07:31 PM   #3
factorystock
factorystock's Avatar
Some reading on the subject. Early 60's to early 70's GM caps were very weak, I would not use an original if there are cracks present. http://67-72chevytrucks.com/vboard/s...cap+metallurgy
factorystock is offline   Reply With Quote
