01-23-2022, 02:00 PM | #1 |
Firewall wire and cable question.
On the passenger side where the cable from the HVAC controls comes through the firewall. Does the blower motor wire also come out that same grommet. If not where are they supposed to exit from the passenger compartment.
Thanks Mark
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
01-23-2022, 02:53 PM | #2 |
Mr. Cheyenne
Re: Firewall wire and cable question.
on my 72 AC/Heater Truck they are routed this way.
now looking at my photo, I think I need to replace one of those vacuum lines .... great, just what I need to do.... go digging around under the dash!
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
01-23-2022, 02:57 PM | #3 |
Thanks. I Think I have the compressor wire coming out by the vacuum lines. But the blower motor is coming out with the cable?
And like most of everything else on this Blazer everything is in need of repair or wrong. Solid body but a serious lack of maintenance. I’m working on it.
01-23-2022, 03:04 PM | #4 |
Mr. Cheyenne
Can't speak for a Blazer but I thought they had the same setup as a Truck.... unless what you have is an add-on AC (not factory)? With the movement of the control cable, I would think it could move back/forth on the power wire and over time cut into the wire's insulation.
01-23-2022, 03:19 PM | #5 | |
01-23-2022, 03:25 PM | #6 |
Mr. Cheyenne
I am not sure what I was thinking about the compressor wire (I translated that as compressor line).
You are correct that the actual cable is inside a sheath but that sheath can wiggle a bit with someone is man handling the controls back and forth. Though likely correct, very low chance of eating into the wire if the sheath is held down on the little tie down claps. My compressor wire meet up with the blower wire (very close to the blower) and becomes one harness / wrapped up then goes into the hole in my photo.
