DEAL ALERT: 1968 C/10 restomod at barret jackson on thursday
This is not a for sale post.
I built this truck back in 2016 with the help of this group. Unfortunately, I never had the time to do a build thread. I sold it last summer for $40K to what turned out to be a high end car flipper. He's running it across the auction block this thursday close to some other well know builds off this site. This could be a steal of a deal due to the fact that I never did any paint work and its a good 20 footer in appearnce. Mechanically, IT IS DIALED! Link to the auction. https://www.barrett-jackson.com/Even...-PICKUP-251912 Build stats... Original Colorado 1968 short wood bed C/10 -all original Colorado metal with the exception of the ( bed header panel, wheel tubs & rockers). Features -Aluminum 5.3l (327) LS engine -TR6060 6 speed transmission w/ hydraulic clutch -5 lug 4 wheel power disc brakes -No Limit Engineering ( NLE) suspension throughout -NLE power Rack & Pinion steering -Stainless steel 2.5” custom exhaust -Vintage Air heat -Optima battery relocated passenger side frame rail under bed -Complete composite bed -No Limit Engineering underbed mounted fuel tank. -3” front, 5” rear static drop (CPP springs & ridetech adjustable shocks) Engine/Driveline -2012 all aluminum 5.3L LS engine with 243 heads. Completely stock with VVT, no DOD, complete GM truck front drive system. -MSD atomic EFi sytem -2014 Tremec TR6060 transmission w/ GM LS3 hydraulic clutch -CORE/ Hurst shifter assembly - Custom Driveshaft shop aluminum driveshaft ( $1000 w/ C/V input from trans). -Original 12 bolt rear end modified by Mark Williams Enterprises. ( 4:10 gear, eaton posi, MW master line axles, shortened axles for correct wheel offset, c-clips eliminated, `1350 series yolk, HD aluminum rear cover). -New U bolts - 20” ridler wheels ( 255 front 295 series rear). Fuel System -NLE under bed mount Baffled aluminum fuel tank. Serviceable from under the truck -Walbro 255lph fuel pump -Holley Hydromat system -PTFE return style fuel line system Chassis - Factory original short bed frame rails - NO REAR C NOTCH!!! - ALL rivets removed/replaced with grade 8 hardware - NLE front/rear frame cross braces - NLE transmission brace - CPP Trailing arm crossmember - blasted/powder coated radiator core support - front wheel tubs were blasted/powder coated/raptor liner on the underside Suspension Front - CPP 2”drop spindles - CPP 1” drop spring - MOOG ball joints - Energy suspension bushings - All parts blasted/powder coated - NLE front sway bar ( custom heim joint end links) - RIDETECH adjustable shocks - POL front shock mount relocation Rear - Stock powder coated trailing arms - Energy suspension bushings - NLE Pan hard bar - NLE shock relocation - 2” CPP lowering block - 2”CPP lowering springs Brakes -CPP big brake kit ( 13” front, 12” rear) -Stainless braided lines - Power brake booster -CPP brake bias controller -In line tube stainless steel lines everywhere -Hawk HTS brake pads -Parking brake assembly functional Interior -Custom blue/black hounds tooth seat cover w/ new foam - Original GM 67’ fold forward bench seat (blasted & painted) -Custom vinyl/sewn door panels ( NOT welded vinyl reproductions) - ALL NEW weather stripping - Roll up windows and vent windows have been completely restored -GM logo 3 point belts ( 2 point in the center) - New matching dash pad -Period correct silver loop carpet from ACC - Matching loop floor mats from ACC - Complete Painless Wiring harness interior, engine bay & chassis - Nu Vintage Guage set - Vintage Air heater/defroster - New window seals - ALL original tinted glass ( vent windows are reproductions) -IDIDit tilt steering column w/ GM reproduction corvette “wood” steering wheel Cooling System - Full size brass reproduction radiator - GM hoses - 180 degree thermostat - DUAL spal electric fan assembly controlled by the Atomic MSD system Exhaust -Doug Thorely Tri Y coated headers - custom 2.5” staines tubes (with H pipe) - Borla Pro XS mufflers ( turned down before rear axle) Body -Colorado rust free original metal truck ( Bed header panel, bed wheel tubs, rockers are AMD metal). -Repainted 7 year ago by the previous owner -Original 50th anniversary fender badges -reproduction grill and headlight surround trim -reproduction chrome bumpers - Blasted/ powder coated hood hinges - side trim and turn signal delete by previous owner BED -support rails were blasted/powder coated -bed wood upgraded to high grade capped decking material -ALL factory bed strip mounting points were reused ( no new holes) -136 Stainless steel fasteners were assembled w/ anti-seize - New AMD wheel tubs ( raptor liner applied to the underside). -New AMD header panel - original tail gate -new bed mount isolators Last edited by Bowtiguy; 01-25-2022 at 12:49 PM. |
| Bookmarks |
