01-26-2022, 08:14 PM | #1 |
Sound Deadening Pattern?
I've been told that sound deadening does not need to be applied wall to wall in the truck cab to be effective. That a certain pattern of patches applied in strategic locations will work. Can anyone verify this or (better still) post up the correct pattern if so?
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus! |
01-26-2022, 10:09 PM | #2 |
Re: Sound Deadening Pattern?
I am not sure I am right but I put sound deadener on unbraced sheet metal. Also, you can tap areas with your fist or something.
For example, there is no need for sound deadener on the cab floor directly above the floor supports or along the seam where the firewall and floor meet. But it is needed anywhere basically 2-3" from such a structure. Basically, anywhere two pieces are welded together or there is a formation in a flat sheet of metal there is no need within 2-4" Another example the back of the cab - you can just put a chunk of deadener maybe 2"x 8" in each of the "vallys" and "hills". The outer door skin needs a piece about 8" x 8" or whatever you can fit. The inner door has enough form, it doesn't need anything. Last edited by cj847; 01-26-2022 at 10:18 PM. |
01-26-2022, 11:53 PM | #3 |
I installed mine similar to the advice above. I only had one box and it is obvious it won’t ad value at weld seams and structured supports. It is not a science and doesn’t need to be perfect or cover every panel completely.
1972 C20 |
01-27-2022, 12:01 AM | #4 |
The Older Generation
I would think if you were using a product that was also considered a thermal barrier it would have to cover the entire surface. At least from the front of the seat forward to the firewall insulation. LockDoc
01-27-2022, 08:04 AM | #5 | |
I used Noico products and they seemed pretty decent for the price.
1972 C20 |
01-27-2022, 09:45 AM | #6 |
This is what I did. As for if it really helps, I’m not sure.
01-27-2022, 10:08 AM | #7 |
Mr. Cheyenne
flip
More has to be better in this case, especially if it is also a heat barrier. It also looks cooler LOL
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
01-27-2022, 10:16 AM | #8 | |
I used Noico 80 mil (2 mm). I still have a bunch left so I’m going to use it on my chevelle. |
01-27-2022, 10:26 AM | #9 | |
6>8 Plugless........
I also agree I would just cover the entire area. You are already there so why not do it all? If you spray sound deadening on, you just don't to the non backed areas IMO.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
01-27-2022, 12:37 PM | #10 |
That's the general approach used by our acoustics guys on the aircraft I have worked on. Lead impregnated polymer stuff in the frame bays, then thermal insulation on top of it all. I'm a structures guy but I think the theory was that it damps out the lower frequencies that the panels would resonate at. The thermal insulation probably helps with the higher frequency stuff. I do know it worked well, the aircraft were dead quiet after the treatment.
01-27-2022, 10:19 PM | #11 |
X2 If it is sound dealer and thermal cover all the floor. Also, the toe board, back of the cab and the I side of the door.
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" |
01-28-2022, 10:08 PM | #12 | |
Thanks |
01-29-2022, 10:30 PM | #13 |
Thanks for all your help, much appreciated!
