![]() Join Date: Nov 2013
Lower A Arms
Put new bushings in my 72 1/2 ton C10, When install the lower a frame I notice A lot of side to side moving. What is the proper way to reinstall Them ? !/2" u bolts holding them in place. Is this part of the alinement process adjustment ??
![]() Join Date: Nov 2017
Re: Lower A Arms
there is a locator pin , in the lower saddles, that must fit into locator holes that are in the control arm shafts, tighten the u bolts evenly, until they are fully torqued, there should be no play, between the saddles, and the shafts, once tightened. front end alignment caster and camber is set by adding or subtracting shims on the upper control arm studs, and tow adjustments are made by turning the tie rod adjuster sleeves, on the steering linkage
Post Whore
![]() Join Date: Feb 2016
Re: Lower A Arms
It is possible that your index pin/rivet could be sheared off. I had that problem on my Burban when I rebuilt my front end. See the link below and scroll to post 244 to see what I found on mine.
https://67-72chevytrucks.com/vboard/...698377&page=10
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
