65 to 72 Disc Brake Conversion
I need some advice and/or knowledge. I have a 65 C-10 that I will be converting to power disc brakes. A friend gave me some 72 spindles with the calipers. I am replacing all of my front end pieces with 72 parts. I can't find a 72 centerlink. How can I connect the tie rods (72) to my 65 centerlink? Can I use a 65 inner rod with a 72 outer? If so, how do I connect them? I know I am not the only one that has run into this.
John Wilson ![]() |
#2 | |
Re: 65 to 72 Disc Brake Conversion
Thank you. I was hoping for an easy solution. So now I can use 65 inner rods and 72 outers, correct?
John Wilson ![]() |
#4 | |
I did the disc swap on my 67/68 years ago. I believe it was by using the drum brake outers as inners & using 71-71 disc outers for compatibility @ the disc spindle. The adapters might be for the drum outers as inners & then 73-up outers. I did the swap around 1990 so forgive my fuzziness on the details. Another good read/source from board member lolife99: http://67-72chevytrucks.com/vboard/s...d.php?t=444823
I just ordered them. The web page said to use the drum brake outers as inners and the disc brake spindle outers, like you said. I appreciate the information.
John Wilson ![]() |
That's exactly what I did for my swap. Works like a charm!
14 Silverado- 4/6 drop daily 66 GMC short wide Custom Cab- building to be low and cruise. 4.8/t56 swap occurring now. Stupid low static drop ![]() 66 GMC 1 ton stepside looooong bed- the tow pig/work truck. |
I'm in the process of building it right now
------------------------------------------- Greetings Harald My 62 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=829782 |
I am also in need of spindle nuts and washers for this build. Does anyone know what size I need for 71-72 spindles? Does anyone have any they will part with?
John Wilson ![]() |
I would imagine you can get them from local auto parts type places or mail-order (Summit) w/o too much fuss.
I would think so too but so far no luck for that year. I don't even know what size it takes.
John Wilson ![]() |
I got mine from RockAuto from the '81 C10, the nut is the same as from my '62/63. Maybe also suitable for you?
#12 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
Did you try that?
#13 |
Thanks everyone. I did some more research and it looks like a 3/4 20 is the size that fits. I ordered some Dormans from Amazon.
John Wilson ![]() |
