Old 01-31-2022, 10:47 PM   #1
nxtruck
nxtruck's Avatar
65’ C10 wiper knob removal
Guys,
Can anyone tell me how the wiper knob is supposed to be removed? It’s a single speed wiper switch and, as far as I can tell, the switch and the knob are both factory pieces. I know the replacement knobs are held on by a set screw, but this knob has no set screw anywhere on it ( and I have looked at it a couple different times ). I’m considering trying to just pry it off of the switch shaft, hopefully without damaging the shaft or the switch. At this point, I really don’t see any other way this knob could be held on to the shaft, but I thought I’d ask to see if anyone else has ran into this.
Thanks in advance for any help!
Chris
1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas
7.02 @ 95.8, 1.45 60'
1965 Chevy C10 LWB, 355 sbc, TH350, daily driver
nxtruck is offline   Reply With Quote
Old 01-31-2022, 11:12 PM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: 65’ C10 wiper knob removal
Should just pop off with a slight pull. My original knob for a switch without washers had a 3 prong metal clip on the inside that held to the switch shaft
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 02-01-2022, 12:14 AM   #3
nxtruck
nxtruck's Avatar
Thanks for the info!
That’s kinda what I was thinking, after not seeing a set screw in it. Thank you for the confirmation!
Chris
Old 02-01-2022, 12:25 AM   #4
cwcarpenter98
Happy to help!
Christian Carpenter
Old 02-01-2022, 10:14 AM   #5
aggie91
I'm just glad to be here!
aggie91's Avatar
Yup, just tug on it till it pops off.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-01-2022, 01:19 PM   #6
nxtruck
nxtruck's Avatar
Thank you, sir! I appreciate the input!
I've got to pull the gauge cluster on this truck in the next few weeks and was hoping not to destroy the knob or the wiper switch when it came time to get that knob off.
Chris
