Small block temperature sender
Looks like the stock location for the temp sender on my truck is on the left side of the engine by the spark plugs. I'm running an Edelbrock Performer and it has two locations that can be used for the temp sender. Anyone see a problem with capping the original location and putting it in the intake?
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
Re: Small block temperature sender
Should be fine
![]() Join Date: Mar 2003
Port you have the sender in feeds the heater core.
Yep you dont want it in that hole
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
Thanks that’s the info I needed. My other issue is sensor thread size. The motor is a Chevy crate that was installed in the 80’s. The original sensor was 1/2” pipe and the block hole is 3/8” pipe thread. At the time I ran in a pipe nipple and adapter. My new sensor is 1/2”. Do they make a sensor for a 70 gauge that is 3/8”? The Edelbrock diagram shows two different temp sensor locations. One is 3/8 the other is 1/2”.
There is somebody on this site that machines them down for this application. Looked for a link and couldn't find it right away
What's wrong with the stock location in the driver's side head?
72 C10 lwb fleetside -stock 350/350 combo |
#8 | |
![]() Join Date: Nov 2013
Brand new AcDelco G1852...correct for 67-72 gauge http://67-72chevytrucks.com/vboard/s...d.php?t=726700
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
The thread size is different. Original block had 1/2 pipe thread replacement block has 3/8.
#10 | |
PM replied...I have 4 in stock ready to ship...
![]() Join Date: Aug 2019
I'm a little confused by all of this I thought the sender went into the cyl head.
#13 | |
There's varying degrees of my mechanics, brothers, uncles' friend who races said one is better than the other. My thought is, the cylinder heads are the biggest issue if you overheat, so why put it in the intake manifold? However... how much hotter is the fluid from one spot to the other, they're like a literal distance of a few inches at best, so idk the scientific, objective answer. ![]() |
#14 | |
the factory engineers designated the cylinder head as the place where the coolant temperature sensor should go… whether you agree or disagree, that’s a fact.
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() Last edited by A1971Blazer; 02-04-2022 at 10:29 AM. |
#15 |
I only asked because the word block keep coming up.
#16 |
Lol i get it.... every time i hear someone say 3 or 4 core radiator i always wonder why they need the extra 3 cores in the first place.
#17 |
It’s my mistake. It is the head and not the block.
#18 |
It's all good...you will have what you need soon...
#19 |
Not trying to criticize, I was just trying to clarify for my understanding.
#20 | |
#21 | |
Post Whore
![]() Join Date: Feb 2016
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#22 |
Got the part today! Fits perfect thanks!
