Old 02-02-2022, 05:19 PM   #1
cwcarpenter98
cwcarpenter98's Avatar
Sending Unit Float
Gas gauge not working? If you've determined that your original or aftermarket brass float has sunk all the way to the bottom, here's your solution!
A plastic float from a Jeep. PN 17729.01 fits nicely in the stock sending unit arm and is a smidge shorter than the factory float.
All I needed to swap it out on my 63 was a 1/2" wrench and 9/16" wrench for the fuel line, 3/8" wrench for the power wire, and phillips screwdriver for the ground wire. Took about 15 minutes and put back together with a NOS gasket I picked up.
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 02-03-2022, 03:35 AM   #2
Braunschweiger
Re: Sending Unit Float
Thank you, great thing
Greetings Harald
My 62 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=829782
Braunschweiger is offline   Reply With Quote
Old 02-03-2022, 03:56 PM   #3
MusicMan70
MusicMan70's Avatar
Thanks for posting with the part number and photo
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
