Old 02-03-2022, 03:24 AM   #1
Iron Hauler
Iron Hauler's Avatar
1972 C20 front suspension removal?
I need to know what's all involved in removing the front cradle. I have the motor out and would.like to remove it all as a unit. Does the suspension need to be broken down to access all the bolts? Is it bolted and riveted? I can pull the front wrap but would like to.leave it on if possible.
Iron Hauler is offline   Reply With Quote
Old 02-03-2022, 01:45 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: 1972 C20 front suspension removal?
It is all bolted in. Some of them are through bolts and some have weld nuts. It all comes out as one unit. Not bad to remove with the engine out. Be sure and spray all of the bolts/nuts with a good penetrating oil a couple of times. If you have a torch heat the nut and bolts before trying to remove them. It breaks the rust bond between the nut and bolt. 4 bolts in the sides and 3 in the bottom. Also disconnect brake lines and pitman arm from center link.
It's an easy swap. Here's a pic of the holes that need modified. You have to enlarge the bottom one because there is a weld nut on the cross member. Some guys doing the swap have said that the bottom hole lined up OK.
LockDoc
Leon
Old 02-03-2022, 01:46 PM   #3
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
No the suspension components do not need to come off first. No rivets all bolts. If I remember correctly it's seven per side hold the cradle to the frame. Four horizontal ones from the outside & 3 vertical ones from the bottom. Plus one more per side if the motor perches are still in place.
Disconnect the pitman arm & the idler arm and everything will come right out the bottom.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver(divorced)
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD(Sold)
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck(divorced)
73 El Camino SS 454 4 speed my first big block
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 02-03-2022, 01:49 PM   #4
67 twins
Looks like Loc Doc is a faster typer than I am lol
Chris
Old 02-03-2022, 01:52 PM   #5
LockDoc
LockDoc's Avatar
...I had to edit mine and add a little more info and I still forgot the idler arm, so it is a good thing you replied also...
LockDoc
Leon
Old 02-03-2022, 03:40 PM   #6
Keith Seymore
Keith Seymore's Avatar
That's how they were installed in the assembly plant.
The front suspension/crossmember was received as a unit. The frame was upside down to help hold the assembly in place while the horizontal bolts and vertical bolts were installed and tightened.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 02-03-2022, 03:46 PM   #7
SCOTI
SCOTI's Avatar
Correct. 14bolts total to remove the entire cradle not including the motor-mount stanchions/towers.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-03-2022, 06:35 PM   #8
Iron Hauler
Thanks for all the info guys. I could have just jumped in and started tearing things down but info like this really helps save time. It amazes me the wealth of information on this board from a group of guys so willing to help out.
Old 02-03-2022, 06:53 PM   #9
leftybass209
leftybass209's Avatar
I didn't see it mentioned, but it is worth noting that removing the springs with the weight of the motor in it for some people is slightly easier. A lot of people have problems with over the counter spring compressors not working or jamming up as well when they have the front end stripped off. Just thought it would be worth noting before you dropped the cradle and possibly can't get the springs out safely.
Best of luck!
leftybass209 is offline   Reply With Quote
Old 02-04-2022, 03:45 AM   #10
Mike Bradbury
Mike Bradbury's Avatar
Yes Scotti brings a good point, if you plan on removing the springs, doing so while it is still on the truck is much safer. C20 springs are much more stout that C10 springs and standard spring comperssors may be over loaded and launch your entire X member across your garage floor taking part of your leg with it. If you are going to completely replace it and are going to scrap the entirety then the whole thing come out quite nicely.
Here is my Drop spindle/ drop spring C20 front ready to go back in.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
