Block stamp?
9v147450
Anybody know how to read this one? 283 or 307 or? 1968 c10 Truck had its heads taken many years ago. The good it sat in a barn. All there. The bad i need a set of heads. And the front window is toast.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
![]() Join Date: Feb 2000
Re: Block stamp?
Any other numbers you can add? Are you sure those are the numbers/letters that are stamped on the front RH side pad of the block? Suffix codes that tell you the engine specifics are made up of letters- typically in the following format after 1956.
T02I4IT First letter is the engine plant Next four digits are the build date The last two or three letters are the suffix code
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
![]() Join Date: Mar 2019
Location: Herculaneum MO (20 minutes south of St. Louis
Re: Block stamp?
Well if it has no heads just measure the bore & stroke. No guess work involved.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
![]() Join Date: Aug 2019
Re: Block stamp?
Take a picture of it.
Re: Block stamp?
Be a few months before any wrenching and measuring.
Re: Block stamp?
Here is a link to use for identifying small block chevy's.
https://nastyz28.com/chevy-engine-code-stampings.php |
Re: Block stamp?
I spent a good hour on there. No luck
Sept flint .... |
Re: Block stamp?
Going to get new cast heads from summit.
It must be a 283 from 67 or 307 from 68. These new heads seem to fit both. Doesnt the 283 and 307 use the same block? |
![]() Join Date: Dec 2009
Re: Block stamp?
I cannot find the Link that states that Remanufactured Engines are assigned a new number sometimes.
This may be the case with this one. With Numbers like that it is a Possibility that it was rebuild by a business-like Grooms (http://crateenginesupply.com/grooms-crate-engines/) or Jasper (https://www.jasperengines.com/)
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
Re: Block stamp?
Can you see the block casting number on the LH rear by the bellhousing? The Lime Book also has lots of good info in it but nothing that matches those numbers.
http://camaros.org/pdf/LimeBook.pdf
Re: Block stamp?
Ya i am stumped.
3 more feet of snow today. Few days ill see what other numbers i can find |
#12 | |
![]() Join Date: Jan 2019
Re: Block stamp?
#13 |
![]() Join Date: Jan 2007
Re: Block stamp?
Can’t help with the block question, but I want more pictures of this truck!
Project "C10 Fever" (68 factory black 396 swb) Project “Faded Glory” (71 c10 med bronze original paint refresh) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
