Old 02-03-2022, 10:59 AM   #1
zac
zac's Avatar
K10 Reman/New Steering Gear
It’s past time to replace mine. I’ve looked at a few threads here, just wondering if there’s some more current input. I have a spare, so I will probably try to rebuild one and use the other for a core. I’ve been on Redheads website, good reputation but a high core charge. Also they say the box fits up to ‘76, but I’m not sure about that. Thought squares had different mounting pads. How’s your luck been with the reman boxes, and what about these new ones?
zac is offline   Reply With Quote
Old 02-03-2022, 11:17 AM   #2
MDFarms
Re: K10 Reman/New Steering Gear
When I spoke to them you can send in core first so you don't get hit with the charge at time of order. They are a good steering gear from what I have learned. Borgeson is about $200 more and I'm not sure why? RedHead claims to custom fit the bearings in them at time of rebuild.
MDFarms is offline   Reply With Quote
Old 02-03-2022, 11:43 AM   #3
6600DURAMAX
6600DURAMAX's Avatar
Following....... at this step as well. I also looked at Blue Top and AGR
1972 K5 - LS3/408 (595Hp) -6L80e-One Tons with 4.56, 20'' Beadlocks with 37'' rubber, full TMI interior, JL Audio .....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 02-03-2022, 07:08 PM   #4
zac
zac's Avatar
The nice thing about Redhead is you can send in your box and have them rebuild it. I tried rebuilding the box from a ‘79 K20 camper special and it turned into kind of a mess. It’s an oddball truck with 14ff rear, 10 bolt front with 8 lug hubs, special brakes, etc. Could never get the right rebuild kit. Wrong bearings and seals, eventually I disassembled some other boxes I had. Was very surprised at all the weird variations I found. Makes me want to be sure I reuse the exact box I have instead of an off the shelf one.
Old 02-04-2022, 04:01 PM   #5
duallyjams
duallyjams's Avatar
I have used redhead steering boxes on 4 trucks. manual & power on 2 wheel drive, power on a 68 4x4.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
