Old 02-04-2022, 01:07 PM   #1
dcmulisha
dcmulisha's Avatar
59 factory cab mount diagram
Anyone have a diagram for replacing factory cab mounts? Original bolts and bushings were removed long ago and I'm replacing them with a new kit from LMC. I want to make sure all my shims and bushings are correct. Thanks
dcmulisha is offline   Reply With Quote
Old 02-04-2022, 02:37 PM   #2
Hcb3200
Re: 59 factory cab mount diagram
instructions here
http://chevy.oldcarmanualproject.com...55ctsm0102.htm
pictures here
http://67-72chevytrucks.com/vboard//....php?p=5236748
Hcb3200 is offline   Reply With Quote
Old 02-05-2022, 09:34 AM   #3
dsraven
google
55-59 chevy truck factory assembly manual
pick the tri5.com site
download the manual and either save it or peruse it. I suggest download and keep a copy becuase there is a lot of valuable knowledge there with drawings, dimensions and the correct way to assembly pretty much everything on the truck. it shows where every spot weld is and how the factory put things together, how te wiring is strung along and each connection etc etc
Old 02-07-2022, 04:30 PM   #4
1project2many
And you should look for the 1957 dealer accessory manual because it shows bits and pieces not found in the assembly manual.
There's also the 1955 2nd series shop manual online if you need it
1project2many is offline   Reply With Quote
