Old 02-05-2022, 01:41 AM   #1
stepsider
stepsider's Avatar
Rear adjustable trac bar
I just install 4" lower springs on my 72 step side. I also install a adjustable trac bar. What is the right adjustment or how do I determent the right ?
stepsider is offline   Reply With Quote
Old 02-05-2022, 01:54 AM   #2
Accelo
Accelo's Avatar
Re: Rear adjustable trac bar
Measure the distance of the wheels to the frame. Make it the same on both sides.
Accelo is offline   Reply With Quote
Old 02-05-2022, 11:17 AM   #3
Zeroman
Zeroman's Avatar
Accelo is correct, but make sure you have the full suspension at ride height...meaning everything is there...bed, bedwood, tank of gas, etc.
I made this adjustment several times during my rebuild.
Zeroman is offline   Reply With Quote
Old 02-05-2022, 03:16 PM   #4
HO455
Post Whore
HO455's Avatar
Here is a link to some photos and a write up from when I installed mine in my Burban. It may help you even though the photos are from above. Scroll down to post 513.
Good luck with the installation.
https://67-72chevytrucks.com/vboard/...698377&page=21
RIP Bob Parks.
Old 02-06-2022, 07:54 PM   #5
BigBird05
I haven't undertaken this yet. Is the new track bar shorter or longer than the stock bar?
BigBird05 is offline   Reply With Quote
Old 02-06-2022, 08:33 PM   #6
Accelo
Accelo's Avatar
It's adjustable. However, it will end up being shorter if it was connected to the same position. Most use the stock top pivot and a relocated bottom connection.
Old 02-06-2022, 08:59 PM   #7
BigBird05
Thanks, but now you have me wondering why change to the bottom connection.
Old 02-06-2022, 09:02 PM   #8
Accelo
Accelo's Avatar
The short story is the longer the rod is the less side movement there is when the suspension is compressed or loaded.
