Senoir Member
Anybody seen this patch panel?
Hey guys. I'm replacing my cab corners on the 67 and found the piece at the rear of the cab on the bottom is rotted....see pic. Does anyone make a patch panel for it? I might can cut a piece off another cab if not.
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4" 70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010 70 GMC Restoration Pictures http://67-72chevytrucks.com/gallery/...00&ppuser=4424 |
All about them Ks
![]() Join Date: Jun 2014
Re: Anybody seen this patch panel?
Years ago when I was doing most of the metal work to my ‘57 that part of the back of the cab was rusted out pretty bad. I bent a replacement out of sheet metal on a brake. Worked perfect and you can’t tell it’s not original to this day. I’ve not seen that part reproduced for the 67-72’s.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5 lift, 35s, front dana 60 blah blah blah http://67-72chevytrucks.com/vboard/s...d.php?t=662879 69 K10 SWB: 4 lift 33s in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20s |
I haven't seen a patch panel for that area. But I have seen the whole back cab panel is available. Cheapest would be to make your own followed by cut out section from a donor cab.
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" |
Senoir Member
The short is yes someone is making a piece. You could cut out a piece and take it to a sheet metal shop and they could probably make you one.
I use it in this video at about the 10:20-11 minute mark: https://www.youtube.com/watch?v=HHYa...omRestorations https://kaminskichassisfab.com/store...ab-pinch-panel $40. I do not receive any $ from referring them. I've used them on two cabs. They were making the 60-66 rear seam, I sent them a template and they have been selling the 67-72 panel since.
70 C20 Build link : Project Montezuma http://67-72chevytrucks.com/vboard/s...d.php?t=794479 How to repair that rusted out 67-72 c10-c30! Please subscribe! https://www.youtube.com/c/MaycoCustomRestorations |
#6 | |
BlahBlahBlah
![]() Join Date: Aug 2019
If you don't have a parts cab I could look at mine in the morning. + I am in SC.
| Bookmarks |
