Old 12-29-2003, 10:08 PM   #1
JimKshortstep4x4
Talking Fender liner questions
I need to buy a pair of new fender liners and I am looking for any comments from anyone that has purchased new ones. I want to know if they fit ok and whether anyone has tried the zink coated ones and how they liked them.
Any comments would be appreciated.
Jim
Old 12-29-2003, 10:20 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I always use genuine GM ones. Of course they fit properly too.
I just bought one for 118 bucks at GM dealer. Aftermarkets are cheaper, but to me, not cheap enough to give them a try.
Old 12-29-2003, 10:28 PM   #3
Blue4x4
Blue4x4's Avatar
I bought Goodmark inner fenders and outside fenders and the two don't match up. The several of the holes are way off. And the Large hole that goes from the top of the inner fender to the bottom outside fender is 3/4 off. These problems are the same on both sides. I had FROST 89434 help me and we never were able to correct this problem. I traded the new skins and put in oem skins. The large hole still doesn't line up. I think the problem is in the Fenders. Check out the pic........
Blue4x4 is offline   Reply With Quote
Old 12-29-2003, 11:50 PM   #4
Canadian694x4
Born To Lose Club
Canadian694x4's Avatar
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
It looks as tho there's a slit in that inner...did you have to do that as part of doing your best to improve the fit?
Brian Smith - "Born To Lose"
1969 Chevrolet K10 LWB Fleetside - Proud Owner For 20 Yrs - 1 of 208 Built & Sold In Canada!
- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's.
1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 2 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds
2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 15 Yrs
- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's.
2008 Yamaha Raptor 700r - Proud Owner For 13 Yrs - ITP Mud Lites.
2015 John Deere 1025R - Proud Owner For 6 Yrs - 24HP Diesel/H120/54D/260B/SB1154.
Canadian694x4 is offline   Reply With Quote
Old 12-30-2003, 03:38 AM   #5
Blue4x4
Blue4x4's Avatar
No slit in the fender....must be the angle the pic was taken. It was also dark.
Old 12-30-2003, 04:12 AM   #6
dinnut
dinnut's Avatar
they sell chrome ones.............. they look really nice but i dont know what look your going for. if it were me id try the new zinc coated ones... ive heard the tooling is alot better on the new fenders but on the inners i dont know... ask the vendors... some of them compare this stuff.
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 12-30-2003, 08:43 AM   #7
JimKshortstep4x4
Talking
I was hoping that some of the vendors would post a reply on their experience!
Jim
Old 12-30-2003, 10:22 AM   #8
MOTHERTRUCKERS
We have never had a complaint on our inner fenders from customers or had any problems with them in the shop but we don't sell goodmark products.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 12-30-2003, 11:42 AM   #9
Tim Christian
Tim Christian's Avatar
Hey Jim, I just installed two new Tri-Plus inner fenders in my son's truck before Christmas. we did get all the bolts in them on both sides a couple was tough getting started but we started them all before we tightened them down. The Goodmark innerfenders do not weigh as much as the Tri-Plus but neither does GM inners they are also lighter that Tri-Plus also. I am working on your e-mail and will send it in a little while. Thanks Tim
Tim Christian is offline   Reply With Quote
Old 12-30-2003, 11:59 AM   #10
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
i put a good mark right side inner fender and core support in mine.
the good mark core support was ok, no problems with it, but the right side inner fender (goodmark) didn't line up with the core support (goodmark) or with the fender very well.
i had to redrill about 5 holes on the new inner fender, and then also contour the lip of the inner fender becayse it was too long.
it took me about 3 hours to install the right side (goodmark) inner fender and about 20-30 minitues to install the left side inner fender (OEM reused GM)
if i was to do it again i would definately use the GM inner fenders
they don't cost much more than the aftermarket.
tommie is offline   Reply With Quote
Old 12-30-2003, 12:11 PM   #11
JimKshortstep4x4
Talking
Thanks for the replies. I think that I will stay away from Goodmark. It sounds like there are good repros available. I know that there is some pulling and tugging that usually has to be done, but Tommie's experience is pretty telling as I have never had to drill any holes in the used fender liners that I have installed.
There just is not any good used liners left in Michigan!
Jim
Old 12-30-2003, 10:23 PM   #12
MOTHERTRUCKERS
We have a TRI PLUS 80.00 inner fender sitting next to a GM NOS 139.00 fender in our shop and the only way to tell them apart is the better less wrinkled stamping and heavier gauge metal on the TRI PLUS. The only part I have seen from TRI PLUS that is not quite up to GM NOS is the full door skins, but the average truck owner would never notice the difference between them after they are installed.
