Old 02-05-2022, 11:03 PM   #1
62bagger
62bagger's Avatar
Shock alignment
I bought a new set of Monroe shocks for the 62. Has anyone had this Problem? Should I just force them into position or is there another issue?
62bagger is offline   Reply With Quote
Old 02-05-2022, 11:16 PM   #2
bhap
bhap's Avatar
Re: Shock alignment
What does the new shock look like next to the old one? Is the bottom bolt bent?
bhap is offline   Reply With Quote
Old 02-05-2022, 11:19 PM   #3
62bagger
62bagger's Avatar
Re: Shock alignment
It didn't have shocks on it when I got the truck.
Old 02-05-2022, 11:40 PM   #4
theastronaut
theastronaut's Avatar
Re: Shock alignment
Looks like a 63-72 crossmember and control arms, is that the original '62 X-frame? Maybe the original '62 upper shock mounts? '63 up frames used a single stud on the frame rail to mount the upper shock, so it seems like someone crossmember swapped a '62 frame and the upper mount doesn't match up with the '63 up shock location.
theastronaut is offline   Reply With Quote
Old 02-05-2022, 11:49 PM   #5
62bagger
62bagger's Avatar
Re: Shock alignment
That is a 63 front cross member on the 62 X frame. It sounds like I will need to get new upper shock mounts. I am not sure how the original 62 shocks mounted. What are other front X member swaps using for the front shocks?
Old 02-06-2022, 12:24 AM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Shock alignment
Maybe add a set of these upper mounts from CPP.
Keith
Convert to disc brakes.
Old 02-06-2022, 12:47 AM   #7
SkinnyG
SkinnyG's Avatar
Re: Shock alignment
It will look really out of wack because you are at full droop. The misalignment isn't anywhere near as bad sitting at ride height. Worry not.
I relocated mine, with a 2" pancake:
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 02-06-2022, 01:57 AM   #8
62bagger
62bagger's Avatar
Re: Shock alignment
thank you for the reply's. I will check out CCP upper mounts and I will also check the shock angle at ride height.
Old 02-06-2022, 06:11 AM   #9
Paul Y
Re: Shock alignment
Or…
Check out post #42 on my build where I made a pair of shock relocation brackets from some box steel.
P.
Woody's Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=658621
If it goes wrong, I blame the Internet...
Paul Y is offline   Reply With Quote
Old 02-06-2022, 07:35 AM   #10
Braunschweiger
Re: Shock alignment
Oh, I'll have to check that too, I have the same conversion. The 62 has the bolt on the lower control arm, the 63 has the pocket for the shock absorber
Greetings Harald
My 62 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=829782
Braunschweiger is offline   Reply With Quote
Old 02-06-2022, 08:38 AM   #11
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: Shock alignment
I moved my front shocks back a little when I bagged it.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 02-06-2022, 03:35 PM   #12
LVPhotos
LVPhotos's Avatar
Re: Shock alignment
I used Porterbuilt that came with kit.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 02-08-2022, 02:15 PM   #13
Braunschweiger
Re: Shock alignment
In fact, the problem occurs to me too, I'll take up Paul Y solution, thanks
Greetings Harald
My 62 build thread
Old 02-13-2022, 09:08 PM   #14
62bagger
62bagger's Avatar
Re: Shock alignment
It looks like Skinny G was right. when I raised the A frame to ride height it lined up. My next question is should there be that much deflection through the travel?
Old 02-13-2022, 10:13 PM   #15
SkinnyG
SkinnyG's Avatar
Re: Shock alignment
It's not an ideal design, but it's worked for sixty years. You'll be alright.
