Old 02-07-2022, 12:37 PM   #1
edflores
1987 TBI K5 No spark
I Bought a 87 k5 350 tbi. Was running at a very high idle ( 2200-2700rpm). Previous owner put on a rebuilt TB. Checked everywhere for vacuum leaks. Found one at the TB base.Still high Idle. Performed TPS relearn. Idle dropped significantly but still a bit high.
Test drive and it dies as soon as you put it in gear. Would sometimes struggle even if you kept it alive, sometime ran like a beast.
I decide to do a tune up. I was advised to do a new distributor.
Replaced distributor, Coil, plugs and wires.
No Spark.
I have replaced ignition modules. Nada
Another new coil. Nothing.
Whole distributor again. Nothing.
I did the test on GM manual and I keep getting bad coil or module.
Injectors are firing while cranking so pickup/ecm seems good.
Only other thing that caught my eye was my dash volt gauge reads low most of the time. like 8 volts. Even if It gets to 12, it drops down very low while cranking.
I still have 12v at the coil though
Any thoughts or ideas?
edflores is offline   Reply With Quote
Old 02-07-2022, 10:02 PM   #2
Pano
Re: 1987 TBI K5 No spark
I have an 87 GMC with a 350 TBI. Several years ago it just died and had no spark. I replaced the distributor, rotor, coils and a few other things.
Finally I replaced what I think I remember is the ignition control module. It is near the distributor, under it or in it. It is small and has a 2 wire connector. Started right up.
Sorry, just reread your post and saw you replaced the ignition module. I do think the 2 wire plug needs to be oriented correctly for it to work. I don’t remember if it was keyed, but worth a look.
Pano is offline   Reply With Quote
Old 02-08-2022, 07:58 PM   #3
Just call me Sean
Just call me Sean's Avatar
Did you try putting the old distributor back in?
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
