Old 02-07-2022, 08:50 PM   #1
ItWillBeSlow
ItWillBeSlow's Avatar
Brothers wood wheel kit
Who has used the Brothers (OER) walnut wheel kit? The hub provided does not match up to my steering column. Customer service has been mediocre so far. The holes in the hub do not align with anything on the column. I am curious if others have done this successfully. My truck is a 72.
1972 C20
ItWillBeSlow is offline   Reply With Quote
Old 02-07-2022, 10:23 PM   #2
70STOVEBOLT
70STOVEBOLT's Avatar
Re: Brothers wood wheel kit
The 2 smaller holes in the hub are for a puller and the larger one is for your horn contact. The 9 screw holes are for mounting the steering wheel to the hub. I have not used that wheel but I have a comfort grip wheel with the same hub.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 02-07-2022, 10:28 PM   #3
Richard
Are the splines wrong in the adapter hub? Should just slide on and secure with the single nut. You need the round part of the horn contact installed before the hub. Larger hole in bottom of hub is probably for the horn contact which may install before the hub as well.
Richard
Old 02-07-2022, 10:55 PM   #4
ItWillBeSlow
Thanks for the comments. I think it will fit and I was thinking about a couple things wrong.
I was thinking the hub needed to bolt to the column, obviously that’s not right.
My steering shaft was pushed in a little and the splines were barely overlapping, I pulled it back and it probably overlaps around 1/4” now which seems sufficient.
Thanks for the help. I didn’t realize the hub was visible and needs painting, looks like I have another project before install.
1972 C20
Old 02-08-2022, 10:02 AM   #5
Custom 68
Custom 68's Avatar
That's a good looking steering wheel.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
