![]() Join Date: Jan 2009
Best black paint brand/shade console paint?
Any suggestions much appreciated.
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Re: Best black paint brand/shade console paint?
I know post is old and maybe you already found some paint but I used SEM Paint on my console going from brown to white and still looks great after 4 years. Bought mine from Walkers in saskatoon but should be a Regina vendor too. https://www.semproducts.com
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
+1 on SEM upholstery spray paint
#4 | |
![]() Join Date: Nov 2018
Yes, paint is Super White and and was used to match my parchment interior. Didn't use anything other than had the brown blasted off and cleaned the console thoroughly before painting. Also took the console completely apart for blasting/ painting. I also painted the inside white as with my 70 year old eyes its easier to find stuff in there.
FWIW I used the SEM primer then color coat on the interior pieces I did (another car) and the final results were excellent
IIRC the "directions" on the color can said use their primer first |
Thats cause they sell the Primer too. Mine is holding up pretty good without it.
Great info. Will get me some of that! Did you glass/media blast or soda blast the plastic?
72 Cheyenne C20 BB, air 70 Suburban 20 BB, air, buckets 68 CST C20 air, buddy buckets |
![]() ![]() Join Date: Apr 2022
I used "the parts place" interior paint/dye. Went that route over SEM as they didnt have a blue to match my interior. I did use Krylon white primer under the blue to get it a shade brighter.
The Twins: 1968 C10 SWB - Blue 327/5 Speed 1968 Camaro SS/RS - Blue 327/4speed C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278 The "Others" 1933 Ford Pickup (Camaro in disguise) 2017 Camaro SS Life long Chevy guy |
I used a SEM bumper stripper spray. It worked really well at cutting any old paint off and not damaging the original grain of the console.
#11 | |
Or you can use the SEM primer which makes the color coat adhere better Clean the item well before either, or both, procedures before applying color coat, It's all in the prep I went from brown trim to grey. |
