Old 02-10-2022, 01:30 PM   #1
Alex69c10
Cost of disc swap vs drum refurb
Hi all,
As part of my mini resto to get my C10 on the Power Tour in June, I am going to completely overhaul the drum brakes, as I have no idea what kind of state they're in. That includes master cylinder too.
I'm just trying to figure if it's just going to be easier to swap over to discs now rather than rebuild the drums and then switch over to discs at a later point.
I really want to know what kind of price I'd be looking at, as I'm not sure what I'd need to convert.
Thanks!
Alex
Alex69c10 is offline   Reply With Quote
Old 02-10-2022, 02:44 PM   #2
swb4me
Re: Cost of disc swap vs drum refurb
I've done both and the actual cost depends on the quality of parts you use. A good rebuild of a 4 wheel drum brake system is $200-$300. A front disc brake kit will run you about $800. You can do the disc brake kit a bit cheaper if you buy used spindles and buy the other parts seperately.. I use the kit because everything you need is included. It's surprising how fast all those little pieces add up when you buy the parts separately.
swb4me is offline   Reply With Quote
Old 02-10-2022, 05:13 PM   #3
Caddylackn
Caddylackn's Avatar
It is getting hard to find good new brake drums. The offshore stuff quality is sub par. Some of the replacement drums don't even have the brake adjustment window cast into them. Good luck gettting those off again.......
Can you have your drums turned by a machine shop, are they usable? And don't ask the national chain brake stores, they no longer do this service.
1969 Custom Camper C20; Factree Air, 350/TH400/Dana 70U with C30 wheel cylinders, Disk brakes, H4 conversion, headlight relay mod, 3G 135 amp alternator. 7500 GVW
Caddylackn is offline   Reply With Quote
Old 02-10-2022, 05:55 PM   #4
Alex69c10
Awesome, thanks for the info! I thought that might be the case. I don’t want to go too wild, as there’s lots of other things I need to get done.
Old 02-10-2022, 05:57 PM   #5
Alex69c10
Yeah, I can imagine. I’ve not gotten them off yet, that’s a job for next week. Though I’m trying to price up what I need. If they’re grooved then I’ll replace. Though I’ll have a look at them once they’re off. I don’t trust cheap Chinese remakes for braking. I’d rather spend the money and stop when I need to.
Old 02-10-2022, 06:12 PM   #6
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Out here, I cannot even give front drum stuff away, no one wants it. When I do get a truck with drums, they get swapped out along with near everything in the brake system.
On the cost, not really an issue if you swap the crossmember. I just got a complete setup for my 68 stepside for 150 with tires and calipers. I could have ran it, but I will change out all the bushings and balljoints and linkages for my own piece of mind.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 02-10-2022, 07:22 PM   #7
Alex69c10
Smitty
What cross member did you get for the 68?
Old 02-10-2022, 07:42 PM   #8
tdangle
tdangle's Avatar
Something to keep in mind also, is swapping to disc from drums require new spindles, bearings, ball joints, tie rod ends, etc. Basically rebuilding the entire front end. If yours is ready for a front end rebuild you want to factor in that cost that would be included in a "kit" I just went thru this with my C20. Would never go back to front drums now. So much improvement, I didn't realize how bad shape my drum brakes were in.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 02-10-2022, 07:49 PM   #9
Alex69c10
I’m with you, there. I’m going to check it all out. If it’s salvageable I’ll probably just rebuild it and see if it’ll survive the power tour! I have big plans which involve big brakes, so don’t want to go wild now and have to change them out later. Though it’s about 25 years since I drove front drums…
Old 02-10-2022, 08:04 PM   #10
cj847
cj847's Avatar
You can spend as much as you want. I think I would fork up for a disk swap. The aftermarket is great, there are tons of options. If you are on a budget, see this link, you can swap brakes from a 71 thru 86 chevy depending on what is available. I personally wouldn't swap a crossmember, just bolt on the A arms and associated steering parts.
http://67-72chevytrucks.com/vboard/s....php?p=4450757
cj847 is offline   Reply With Quote
Old 02-10-2022, 08:27 PM   #11
Alex69c10
That’s awesome! If I need to switch out the master cylinder I might as well go for a disc brake one. Thank you for the information!
Old 02-10-2022, 09:04 PM   #12
71meangreenc10
It was off a square with rubber bushings. Goes in easy, drill one new hole on each side and elongate one existing hole. Everything else bolts right in.
Smitty
71 C30 Wrecker
Old 02-10-2022, 09:57 PM   #13
kwmech
Still have 4 wheel drum on my 68 3/4 truck. Runs and stops just fine--even overloaded now and then
Old 02-10-2022, 10:06 PM   #14
Alex69c10
Thank you, all! I appreciate the information. I like discs so I’ll price them up and see what I need to replace anyway! See where we go.
