Old 12-29-2003, 11:25 PM   #1
Frank-id
GM steering shafts needed
I have an old Crown bus that I'm making into an RV. The steering wheel is 22.5 inch diameter. The wheel spline is very different than any others. I have cut the shaft and need a GM shaft to change to GM steering wheels. I'm gonna use a factory Chevy pickup 16 inch wheel.. My buddy brought to me a tilt wheel shaft from a buick. The shaft is too short. I need about 3 of these shafts. The shaft needs to be about 12-15 inches long. Here in Idaho, there are not a lot of shafts available. I will pay a fair price and shipping... My addy is...
frank-id@velocitus.net...
My Crown bus project.. below.
Chevy stepper 400sb 350 turbo
Frank-id is offline   Reply With Quote
Old 12-29-2003, 11:49 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
send me a ppic of the shaft ya need i have at least one here if its what i think it is
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-30-2003, 12:49 AM   #3
Frank-id
GM steering shaft pic
GM tilt wheel shaft...
I need shafts that are longer...
Old 12-30-2003, 12:51 AM   #4
Frank-id
tilt shaft
pics are exchanged..
Old 12-30-2003, 01:10 AM   #5
Russell
Professional Grade
Russell's Avatar
I've got one of those things lying outside, the top end is slightly damaged due to a homemade wheel puller, but it still works well (threads not damaged, the bolt will still go onto it)
I also have the long shaft that attaches to that knuckle joint, Its in good shape. I can get pictures if you want them, if it is what you are needing anyways...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 12-30-2003, 01:39 AM   #6
Frank-id
Shaft needed has no joint
I'm needing the NON tilt steering shaft..
I want to do a little cutting, machining and welding...
Old 12-30-2003, 01:53 AM   #7
1974ChevyC10
Overworked and Underlaid
1974ChevyC10's Avatar
are you talking about the shaft in the steering column itself or the shaft that goes to the steering box b/c if you can wait a couple weeks or so once i switch over to a tilt column into my 78 ill have a steering shaft you can use.lemme know or pm me for more detail.
I'd rather push a Chevy than drive a Ford
The Beast-1978 C10 LWB
Red-1978 C10 LWB
(Uncle Mike)Michael Henry Millett 11/5/1957 to 03/08/2012
Gone but will never be forgotten-RIP
(Uncle Chuck)Charles Manning Gulbronsen Sr 1956-2012
Taken from us to soon but you will live on in our hearts-RIP
1974ChevyC10 is offline   Reply With Quote
