Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 02-11-2022, 03:15 PM   #1
nsb29
nsb29's Avatar
Wanted
I need an Original pinion nut and washer for my 65 12 bolt The original hardened washer is the most important part but nut not so much so
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 02-12-2022, 06:21 PM   #2
duallyjams
duallyjams's Avatar
Re: Wanted
Are you looking for a new or used ?
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 02-12-2022, 07:41 PM   #3
nsb29
nsb29's Avatar
Re: Wanted
Used washer, as the original washer is hardened the ones you get are stamped from mild steel and become concaved before crushing the sleeve I have called several companies who offer a replacement nuts and washers and they don’t know if they’re washer is hardened or not the ones you get from Richmond gear are not nuts you can get anywhere
Old 02-13-2022, 12:04 PM   #4
MT65
Re: Wanted
Why don’t you case harden it yourself, I’m sure the temperature necessary, probably red hot is out there to be found, a container of used oil to quench it and you have your part….
MT65 is offline   Reply With Quote
Old 02-13-2022, 03:47 PM   #5
nsb29
nsb29's Avatar
Re: Wanted
And if you over temper it ?
It will brake
I know there are a lot of scrap 12 bolts sum one will have one or sum one will tell me who sells a hardened one
Old 02-13-2022, 07:31 PM   #6
MT65
Re: Wanted
Being this is under compression with something behind it, I would highly doubt that, its not rocket science, I watch my friends who make precision parts for weapons do it regularly, just get your temperature you need to hit and make it happen…or just wait for someone…….
Old 02-14-2022, 12:35 PM   #7
nsb29
nsb29's Avatar
Re: Wanted
We’ve all watched forged in fire
Old 02-14-2022, 10:39 PM   #8
MT65
Re: Wanted
You may have , myself, not so much, I prefer to deal with professionals, not wanna be….
Old 02-15-2022, 11:24 AM   #9
nsb29
nsb29's Avatar
Re: Wanted
Originally Posted by mt65 View Post
you may have , myself, not so much, i prefer to deal with professionals, not wanna be….
lmao
Old 02-15-2022, 11:56 AM   #10
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Wanted
Says it's hardened - https://www.strangeengineering.net/p...n-washer.html/
Old 02-15-2022, 04:38 PM   #11
nsb29
nsb29's Avatar
Re: Wanted
Yeah I checked them out but like so many times it isn’t what it says it is the opening in the yolk is 1.58 the washer they sell is 1.73 Dennys drivelines says they have the nut and washer I’ll check them out Yukon gear Richmond gear all of them say made in the USA but they buy all the parts from somewhere else
Old 02-24-2022, 09:04 AM   #12
uncle
Re: Wanted
Ever find one? I probably have one. Will check this weekend.
uncle is offline   Reply With Quote
Old 02-24-2022, 11:45 AM   #13
nsb29
nsb29's Avatar
Re: Wanted
Yes I did finally end up coming up with one there is a guy on eBay that makes them two OEM specifications the ones you get in the kits are junk the most important thing to remember is don’t loose your original one LMAO Thanks for the offer
Old 02-25-2022, 11:05 AM   #14
The Rocknrod
Moderator
Re: Wanted
You got a link or a seller name?
Old 03-01-2022, 05:37 PM   #15
nsb29
nsb29's Avatar
Re: Wanted
Originally Posted by the rocknrod View Post
you got a link or a seller name?
Old 03-01-2022, 05:41 PM   #16
The Rocknrod
Moderator
Re: Wanted
Thanks, your seller All Powersports Drivetrain - https://www.ebay.com/itm/19239887496...0AAOSw-09aNBZx
Quick has them also - https://www.ebay.com/itm/39143528587...EAAOSwYmZXElEz
Big difference I see.
Old 03-02-2022, 10:49 AM   #17
nsb29
nsb29's Avatar
Re: Wanted
It’s hard to know looking at a picture but the one from Quick looks like they are just stamped steel like the junk that comes in the kits so I went with powersports and its quality
