Old 02-13-2022, 06:41 PM   #1
CG
BlahBlahBlah
Side Marker or Tailight fuel filler?
I like the idea of side marker or taillight gas fill mods, but getting the cap off seems way to cumbersome. Has anyone tried this type of gas cap?
https://www.speedwaymotors.com/Hagan...Cap,50078.html
Old 02-13-2022, 06:57 PM   #2
Thealien
Thealien's Avatar
Re: Side Marker or Tailight fuel filler?
I am planning on using that same cap on my tail light fuel filler on my blazer. That’s probably many months away from being done though. So how well it works in reality is to be seen?
I hope someone that’s actually using one speaks up.
Old 02-13-2022, 07:39 PM   #3
mi396ss
I’m using that cap on a side marker light filler and it works great.
mi396ss is offline   Reply With Quote
Old 02-13-2022, 07:43 PM   #4
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I was wanting to go with the side marker light fill but after looking it over the fellow installing my rear tank suggested a rear corner box filler. I told him to do it and am happy with the results. He used a gas fill tube from a wrecked 1990 Burb that had the vent tube attached. I decided to leave the cab fill cap in place and I've taken the truck to a few shows since the rear tank install and no one even notices it in the box corner.
1992 K1500 GMC Suburban
" In the end, we only regret the chances we didnt take "
" Time is the only currency we spend without knowing the balance, use it wisely ." ..
Old 02-13-2022, 08:57 PM   #5
indymachinist
Here is mine. Still not 100% finished. One of the new capless fill styles. They come on a lot of new cars now and are pretty easy to find/remove from junkyard cars.
-Curt
My 1968 Chevy shortbed stepside build
indymachinist is offline   Reply With Quote
Old 02-14-2022, 03:00 AM   #6
HeavyHauler
Could you explain how you made your side marker light fuel filler set up and what all did you use to make it all work?
HeavyHauler is offline   Reply With Quote
Old 02-14-2022, 10:52 AM   #7
old51sedan
old51sedan's Avatar
This style of cap makes it so much easier, it seals itself tight, and no hassle sitting it down and for getting to put back on. I used this set up when doing my stepside and it worked out well.
old51sedan is offline   Reply With Quote
Old 02-14-2022, 01:14 PM   #8
michael bustamante
michael bustamante's Avatar
i like this. did you make a thread by chance?
1967custom
michael bustamante is offline   Reply With Quote
Old 02-14-2022, 04:26 PM   #9
BigBird05
Is that the one or like the one from Speedway motors. There's is a Quick release cap.
BigBird05 is offline   Reply With Quote
Old 02-14-2022, 06:10 PM   #10
LS short box
Ford has had this style of cap for many years. My 2020 Silverado has a similar style cap.
LS short box is offline   Reply With Quote
Old 02-15-2022, 04:58 AM   #11
Richard
With the modern bellows type nozzles in gas stations where I am located, cannot see either of the options mentioned desirable to me. I just integrated a fuel door in bed side for ease of use. All vehicles have a fuel fill. IMO a door on the fill location is less obvious than the stock fill location. Will look stock to anyone not knowing the difference and "custom" to someone who knows.
My wife's newer Blazer has one of the caps you fill through without removing. Expecting to replace in the near future due to leaks causing an emissions fault.
Richard
Old 02-16-2022, 01:36 PM   #12
old51sedan
old51sedan's Avatar
No I did not, did this a few years ago, also hid the bolts that hold the bed on the frame which I thought gave it a cleaner look.
Old 02-16-2022, 07:17 PM   #13
CG
BlahBlahBlah
Good comment, I didnt even think about the weird filler via the pump.
Old 02-18-2022, 08:42 PM   #14
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Here is what I did for Beth's Tribute Truck.
https://67-72chevytrucks.com/vboard/...=820543&page=5
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 02-19-2022, 08:39 AM   #15
BigBird05
Already Gone, yours is one of the nicest ones so far, but it still leaves the fuel cap in the bed.
Old 02-20-2022, 10:31 PM   #16
Peanut74
I put mine in the rear post hole. I used a pop up motorcycle filler cap to give it a flush look. I went this way because mine is a '67 so I don't have side marker lights. Also wanted to have access to fill it when I'm hauling something.
1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion)
1989 Toyota DLX pickup "The Hulk"
Peanut74 is offline   Reply With Quote
