02-14-2022, 02:39 PM | #1 |
Power Steering Pump and Bracket Part numbers - SWP/Drivers Low mount
All,
I'm getting set to do the PS swap into my 66 C10 using Captain Fabs bracket. Looking on ebay for "SBC Short water pump Power Steering Bracket", I see at least a half dozen different options. Would prefer to run a factory GM bracket vs a universal aftermarket one... The details of the truck: New SBC 350 crate engine Short Water Pump Alternator mounted on Drivers side high mount. Does anyone have a list of Part Numbers, that they used that worked? Looking for the following: Pump Bracket Pump Pump Pulley and less urgently: Crank Pulley Waterpump pulley Alternator Pulley Thanks! |
02-14-2022, 03:36 PM | #2 |
Moderator
Re: Power Steering Pump and Bracket Part numbers - SWP/Drivers Low mount
Yes, I'm using Alan Grove and they line up perfectly.
http://www.alangrovecomponents.com/S...Short_Pump.htm 132R - A.C. 232L - Alt. 400L - P.S.
02-14-2022, 04:52 PM | #3 |
Thanks RocknRod!! I called Alan Grove, those guys know their stuff. Ordered the bracket, crank pulley and pump pulley! Much easier!
02-15-2022, 05:59 PM | #4 |
I used the AG low brackets (LWP) but had the misfortune to have the wrong style pump, so ended up like this:
A new pump with the correct mounting configuration sorted it, and it was all detailed in their literature so was an easy fix.
Barney, in the UK 1962 Chevy C20 1974 Ford Econoline 1987 Peugeot 205 GTi 1991 Peugeot 205 GTi |
02-15-2022, 11:12 PM | #5 |
Guess I'm a little late,, but for the record here is my experience with the Borgeson P/S pump bracket.
https://67-72chevytrucks.com/vboard/...d.php?t=830026 |
02-16-2022, 11:26 AM | #6 |
You'll be happy with the Alan Grove stuff. I have their power steering brackets on both my 64 C10 and my 65 Impala.
On both vehicles, the power steering belt runs VERY close to one of the brackets, but it has never caused any issue and I drive my vehicles quite a bit. |
02-16-2022, 12:25 PM | #7 | |
02-16-2022, 12:38 PM | #8 | |
I have used Alan Grove brackets on two vehicles over the years. Not cheap, but they are the absolute best! I've also bought Canadian-made pulleys from a local hot rod shop. Again, not cheap, but no wobble like the Chinese crap.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
02-16-2022, 12:59 PM | #9 | |
Moderator
