Old 12-30-2003, 12:51 AM   #1
76HighSierra
DAMN, I love Big Blocks!
76HighSierra's Avatar
Painting Aluminum Intakes
I've noticed a few of you have painted your aluminum intakes. I have an Edelbrock Performer that will be going on my 454 when I rebuild it in the spring, and I want to paint it engine color. The problem being, I know paint does not stick well to aluminum. Anybody have any recommendations as to a product or procedure that will help the paint adhere permanently ?
Marc Bona
Hobbs, New Mexico
1976 1/2 ton GMC High Sierra.
454 c.i.d./ TH400. *Soon to get a mild warming over.*
3.40 rear.
76HighSierra is offline   Reply With Quote
Old 12-30-2003, 01:06 AM   #2
Russell
Professional Grade
Russell's Avatar
some sort of etch primer?
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 12-30-2003, 01:07 AM   #3
Cole's 87
Cole's 87's Avatar
I have the RPM Performer, all I did was clean mine with alumi-brite. Then rinsed it let, it dry off & painted it with no problems. Havent had any paint come off yet and that was well over a year ago.
Cole's 87 is offline   Reply With Quote
Old 12-30-2003, 02:14 AM   #4
ol84
get it powder coated if you can afford it.
1984 C10 SWB
Custom Frame
Blow Through Carb Single Turbo
Hope to be on the road by Summer 2018
1967 C10 CST LWB
327/PG Original
Running Driving Future Project
ol84 is offline   Reply With Quote
Old 12-30-2003, 02:34 AM   #5
mike reeh
5 day ban, learn to behave.
mike reeh's Avatar
Is the intake new? If its used, just clean it real well. Bead blasting it would be ideal, but if you cant, then clean the hell out of it..
I think paint sticks to the porous, rough cast finish better than anything.. If you use a good engine paint like that 500 degree stuff, and put several thin coats, it will hold up well.. I wouldnt even primer it
mike
mike reeh is offline   Reply With Quote
Old 12-30-2003, 02:59 AM   #6
76HighSierra
Thanks for the replies, guys! As always, you're the best.
Marc Bona
Hobbs, New Mexico
3.40 rear.
Old 12-30-2003, 03:35 AM   #7
Big Paul
Iamnotanofficerofthelaw
Big Paul's Avatar
Watch out though, that Dupli-Color 500* and 1200* paint isn't gas and oil resistant. Although it says so on the can.
I sprayed a Briggs & Stratton gas tank with the 1200* stuff. I coated it pretty thick, the carb leaks and ruined the paint. If you look at my avatar (thats the engine) it's nice and shiny, I took a wire wheel to it cause of the damn paint.
Powdercoating is very nice. Shouldn't cost too much, maybe $50. That's what i'd do, unless you can find a paint that's truely gas and oil resistant. But why should the carb be leaking anyways?
~Paul~
'96 C1500 Silverado- Vortec 5.0L/Exhaust/Stock
'87 S-10 Ext Cab- 2.8L/700r4
KIA Caught fire 12/7/03
Big Paul is offline   Reply With Quote
Old 12-30-2003, 04:53 AM   #8
stepside454
stepside454's Avatar
I use plastic coat...make sure its very clean
75 GMC C-15 short/step factory 454, lowered
stepside454 is offline   Reply With Quote
Old 12-30-2003, 03:35 PM   #9
ItsNotABlazer
The full convertible guy
ItsNotABlazer's Avatar
I once bead blasted an weiand intake and didnt paint it but just sprayed clear over it. Looked pretty cool and definitely something different..............sorry i do not have pics of it. I would agree though about powder coating it if possible.
Brad
2012 Kawasaki Vaquero (Lime Green)
2000 BMW 740iL
1995 Chevy ECSB riding on air
1975 GMC Jimmy 2WD lowered 4/6
1972 Chevy Trazer soon to be roadster
1965 Mustang 289/3 speed (friends dad bought it new)
1964 Chevy C10 (dad bought it new)
ItsNotABlazer is offline   Reply With Quote
Old 12-31-2003, 01:49 PM   #10
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
I blasted and then epoxy primed my complete motor and then shot base coat/clear coat on it.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 12-31-2003, 04:18 PM   #11
76HighSierra
All this talk about powdercoating......I have a powdercoating system, but is there anywhere where you can get powderpaint in chevy orange? Or VERY close to it?
Marc Bona
Hobbs, New Mexico
3.40 rear.
Old 12-31-2003, 04:24 PM   #12
Captkaos
Captkaos's Avatar
http://www.eastwood.com has Chevy Orange powder.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
