cross brace removal before removing SM420 transmission
I have a 1964 c10 stepside with SM420 Transmission. Need to replace clutch and was wondering if I need to remove cross brace (has rivets) before trans removal.
I have a 1963 shop manual and it does not address removing cross brace. Thanks for the info! |
Moderator
![]() ![]() Join Date: Aug 2011
Re: cross brace removal before removing SM420 transmission
I think post #4 and then a correction on post #6 here - http://67-72chevytrucks.com/vboard/s...d.php?t=400660
#3 | |
![]() Join Date: Dec 2009
It will be time well spent when you go to reinstall and align the trans to the clutch splines and pilot bearing.
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 85 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
Which brace are we talking about? On my 64 there was the rear engine mount crossmember that the bellhousing bolts onto (riveted in) and there is a parking brake mechanism crossmember that was bolted in. There shouldn’t be a reason to remove a riveted-in crossmember to service the clutch…
My '61's crossmember is (was) welded. That ain't being removed.
Drop the box off the bellhousing first.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
Thanks , I wasn't sure if the trans will fit out the bottom without taking either the engine crossmember or parking brake crossmember out . Casey jones says its doable, so next week ill give it a go. I will make trans top bolts pins by cutting heads off bolt so it slides easier. Thanks for the replies, appreciate it!
Yep, I took mine out from above with an engine hoist. Good luck and be safe!
I took the SM420 out this weekend. it was easier to take it out thru the top, but I am going to grind down the rivets on the parking brake support and remove for easier installation after I rebuild the transmission. with the parking brake support out of the way, it will be super easy to slide transmission back in using 1/2 inch bolts as a guide on top two bell housing holes. I used a 3 1/2 inch bolt with the head cut off as a guide, then you can slide trans easily into place by yourself.
| Bookmarks |
