Old 02-20-2022, 12:55 AM   #1
CS1972
CS1972's Avatar
WTB 4x4 Factory steering stabilizer shock bracket
Ordered a new steering stabilizer shock and tie rods for my 72K10 and then today when I went to install I finally (after 2.5 yrs) noticed that the bracket and associated hardware that attaches to the steering stabilizer bar, which I need to attach the stabilizer shock to is missing. Not sure why someone would take that all off and throw away.
The attached pics are what I need so I can finish this up - Bracket, Ubolts washers & nuts.
UPDATE: NO LONGER NEEDED, Dieselwrencher had one
Ron
1972 Cheyenne Super 1/2 ton LWB 4x4 - Grapefruit Yellow / White
Last edited by CS1972; 04-25-2022 at 10:41 PM. Reason: Letting audience know I've found one
CS1972 is offline   Reply With Quote
Old 02-26-2022, 11:22 AM   #2
CS1972
CS1972's Avatar
Re: WTB Factory steering stabilizer shock bracket
Still looking............if all you have is the bracket to sell "I'll take it".
Ron
Old 04-03-2022, 04:02 PM   #3
CS1972
CS1972's Avatar
Still look'n
Ron
Old 04-03-2022, 09:16 PM   #4
davischevy
davischevy's Avatar
I went out back and looked the other day, and I don't have one. I have been keeping an eye out ever since you mentioned it.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 04-08-2022, 03:17 PM   #5
CS1972
CS1972's Avatar
TTT for the weekend.........
Ron
Old 04-08-2022, 11:47 PM   #6
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
I know your wanting the factory bracket but this would work till you find one.
https://www.ruffstuffspecialties.com...RoCOuwQAvD_BwE
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 04-09-2022, 12:47 AM   #7
CS1972
CS1972's Avatar
I looked at using the Ruffstuff Flat Mount Steering Stabilizer Bracket, however, they only make it for 1.5" OD and the stabilizer bar on our trucks is 1.25" so I think the Ubolts & bracket would be a little sloppy.
Ron
Old 04-09-2022, 01:23 AM   #8
BLAZERMAN
BLAZERMAN's Avatar
This might work for you then.
https://www.ebay.com/itm/RockJock-CE...-127632-2357-0
Old 04-16-2022, 08:50 AM   #9
72ironmike
72ironmike's Avatar
Ron, I put a wanted on the 73-87 board. If one shows up it's yours.
72ironmike is offline   Reply With Quote
Old 04-16-2022, 10:30 AM   #10
CS1972
CS1972's Avatar
Seems odd to have that precise measurement of "19.06", but then you have leeway of 1/8" - plus or minus.
Ron
Old 04-16-2022, 10:57 AM   #11
Tmend
Tmend's Avatar
I may still have the shock which I believe is the original one. I can measure fully extended and full collapsed. I’d say the mid point is good for install l. Let me know
Some progress is better then no progress
Tmend is offline   Reply With Quote
Old 04-19-2022, 08:57 AM   #12
CS1972
CS1972's Avatar
TTT ......... I made a bracket that is working, but I still want the Factory OEM bracket (as pictured below) if anyone has one.
Ron
Old 04-25-2022, 10:40 PM   #13
CS1972
CS1972's Avatar
I no longer need one as Dieselwrencher (Ryan) took good care of me.
Ron
Old 04-25-2022, 10:52 PM   #14
davischevy
davischevy's Avatar
You've got the love this place if you like these trucks.
other Larry
