02-22-2022, 10:32 AM | #1 |
Fresh air Vent under cowl
I've been searching for information on the A/C-Fresh air venting for my 70 C10. I think I have it all figured out as to how it works but now I have an issue with my original vent. As you can see in the picture the pivot has broken off. I believe I could JB weld it and it will hold but also the rubber seal is dried out and breaking off. I searched some of the vendors but I couldn't fing a source for the vent or the rubber seal. I would like to keep the system as it was originally designed. Any suggestions would be appreciated.
Terry |
02-22-2022, 10:41 AM | #2 |
Re: Fresh air Vent under cowl
02-22-2022, 10:45 AM | #3 |
Thank you Jason!
02-22-2022, 11:37 AM | #4 |
20' Daredevil (Ret)
LMC also has that, p/n 32-0790, A/C Air Shut-Off Valve, $29.95. Page 180 of the PDF catalog. https://media.lmctruck.com/pdf/CB/cbComplete.pdf
02-22-2022, 11:44 PM | #5 | |
Posted via Mobile Device |
02-23-2022, 03:51 AM | #6 |
Classic parts > LMC
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
02-23-2022, 10:08 AM | #7 |
Thanks for the help on finding a vendor. Thought I would try to fix the one from my truck. Some JB Weld and rubber gasket material. Hopefully it will hold up. If not now I know where to get a replacement.
Terry |
02-23-2022, 02:03 PM | #8 |
I've found that jimmy-rigging broken/worn GM parts, I can expect fit and functionality 1000% better than brand new Chinese parts. True story!
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs |
