Old 02-22-2022, 07:09 PM   #1
stepsider
stepsider's Avatar
Points to HEI Question ??
Going to get rid of my Points Dist And go to GM HEI. Is there any resistance wiring to remove no ballast resistor in system now ??
Is it going to be a simple change over ?
stepsider is offline   Reply With Quote
Old 02-22-2022, 07:34 PM   #2
71gmcC15
71gmcC15's Avatar
Re: Points to HEI Question ??
The power wire for points has built in resistance. Have to replace that wire for full 12vs
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )
94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless
07 gmc sierra classic rcsb 4.3 lt 5 speed w/t
04 chevy Silverado 1500 ext cab 5.3 4l60e.
81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green)
71gmcC15 is offline   Reply With Quote
Old 02-22-2022, 08:06 PM   #3
stepsider
stepsider's Avatar
How far back to replace ? I imagine the source. Correct ?
Old 02-22-2022, 08:50 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
When I did mine many years ago (pre-internet) I ran a 12 ga wire from the HEI to the bulkhead. IIRC, I used the IGN UNFUSED pin for power (lower right on the bulkhead).
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 02-22-2022, 08:51 PM   #5
pjmoreland
pjmoreland's Avatar
Here's what you will want to do:
https://67-72chevytrucks.com/vboard/...d.php?t=708975
pjmoreland is offline   Reply With Quote
Old 02-22-2022, 09:16 PM   #6
67C10Step
67C10Step's Avatar
Originally Posted by pjmoreland View Post
This is pretty much the exact thing I followed. Got the connector ends for the bulkhead at my local Napa along with the wiring wrap.
1967 C10
1997 Ford Ranger
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 02-22-2022, 09:31 PM   #7
JAV6
JAV6's Avatar
This! I did this a few months ago and it was a massive improvement. Don't forget to open up the gap on the plugs (.45-.60) and adjust timing advance.
1968 GMC 1500 LWB 350 V8/TH700R4
1970 CST-10 SWB 350 V8/3-Spd Saginaw
1967 C-10
JAV6 is offline   Reply With Quote
Old 02-23-2022, 02:25 PM   #8
bry593
12 AWG GXL Pink with Packard Electric (Type 56) terminals. You'll need about 4 feet to go from the HEI (bat +) to the firewall bulkhead. Simply remove the old wire (stainless steel did you know?) and plug into the same socket.
Also, remove that secondary yellow wire going down to your starter. It is no longer required. Was a resistance bypass when starting the car. Pretty common on old GM points cars.
Plugs should be gapped to .045" and wires changed to 8mm.
Also, avoid the Chinese HEI as these are complete junk. Find an old original GM dizzy from the 70's and it will work perfectly.
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs
bry593 is offline   Reply With Quote
Old 02-23-2022, 04:13 PM   #9
72bowtiestepper
I think you mean .045 - .060 gap
.45- .60 is over 1/2 inch !
72bowtiestepper is offline   Reply With Quote
Old 02-23-2022, 05:07 PM   #10
JAV6
JAV6's Avatar
Hahaha, you are correct!
1967 C-10
