Old 02-23-2022, 12:12 AM   #1
UrbanC10
Post Ball joint taper?
Hey guys,
Long story short I'm using a set of 71-72 drop spindles on my 63 so I have to run 71-72 inner/outer tie rods and adjusting sleeve, which means I have to ream the hole on the center link that the inner tie rod connects to.
the 72 inner tie rod (moog-es403l) has a tapered stud diameter of
.625 to .566
does anyone know what degree of ream bit I need?
I found online that it could possibly be 7* or 10*
Any help is appreciated, thank you.
UrbanC10 is offline   Reply With Quote
Old 02-23-2022, 07:18 AM   #2
CarlsLQ9SS
CarlsLQ9SS's Avatar
Re: Ball joint taper?
I think you can use the 71-72 inner drag link and avoid reaming the one off the 63. Lowlife99 has a detailed write up on this somewhere.
Carl
1971 GMC short bed, (Henry)
Options I've added, tilt, ac, 8k tach,
Electric speedometer conversion for LS swap,
6.0 with 823 heads and BTR stage 4 truck cam,
4L80e, posi with 3.73 rear end,
Power steering and power brakes
Lowered 5/7. Frame up build.
CarlsLQ9SS is offline   Reply With Quote
Old 02-23-2022, 12:24 PM   #3
pjmoreland
pjmoreland's Avatar
The disc conversion kit I installed on my 68 used the larger 71-87 outer tie rod ends with the original smaller outer tie rod ends moved to the inner position. The kit came with special adjusting sleeves to join the mismatched tie rod ends together. I wonder if this setup would work for you. Here are the adjusting sleeves.
https://www.performanceonline.com/19...ONVERSIONS-Pr/
pjmoreland is online now   Reply With Quote
balljoint, taper, tie rod
